Scary stalling Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Lemon?, Jun 16, 2022.
  1. Right2Know
    Right2Know Junior Member
    West Sacramento, CA
    2014 Prius v wagon
    The fluid in the coolant reservoir has turbulence when the car is on. I believe that means the inverter coolant pump is functioning. No leaks noted.
  2. Right2Know
    West Sacramento, CA
    2014 Prius v wagon
    U0110 Lost Communication with Drive Motor
    Control Module "A" cable Inverter w/ Converter Assy. Converter
    DTC: C1256 Accumulator Low Pressure Tire Pressure "Brake Booster Assemvly with Master Cylinder TSB-0024-19
  3. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    The pump could be stalling out; as you stated - it's intermittent and only happens every few months.
  4. Right2Know
    West Sacramento, CA
    2014 Prius v wagon
    Here they are: U0110 "Lost Communication with Drive Motor Control Module "A", C1256 Accumulator Low Pressure, C2124 Cannot Receive a Data from Transmitter ID4 (Main), and B1507 Open in Turn Signal Circuit.
  5. BiomedO1
    4,639
    2,434
    Left Coast
    It's the U0110 & C2124 code that's causing the shut-down.
    Is this a salvage title car? is the wiring harness intact? Has the car been in a flood? are there rodent chew marks on your wiring harness?
  6. ChapmanF
    19,060
  7. Right2Know
    West Sacramento, CA
    2014 Prius v wagon
    Clean title not salvaged. It actually looks new though 10 years old. Dealer examined the car over many days. No mention of wire damage. Not sure if it has been in a flood. Not sure about rodent chew marks.
