Scheduled Maintenance Guide
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by athas17, Apr 19, 2018.
  1. athas17
    athas17 Junior Member
    Los Angeles
    2019 Prius
    A service mgr told me a few yrs ago that a Prius can easily pass 300,000 miles. However, I've just reached the last pg in my maintenance guide which suggests maintenance at 120,000 miles. I am only slightly past that. Called Toyota and it seems they don't print a booklet for over 120,000. Doesn't make sense to me! The gal on the phone said just "start over" with page 1! I guess I'll have to start using notebook paper because I don't like having to dig thru receipts from the shop.
  2. JC91006
    16,889
    8,625
    You can log all of your repairs online at the Toyota owners website. You'll see all your repairs done at a Toyota dealer and you can put manual entries yourself if you want to (like when you change an air filter)
    Bk7king, athas17, SFO and 2 others like this.
  3. Mendel Leisk
    42,096
    If you take the US schedule, interval-by-interval, and enter it into a graph (spreadsheet, or even just paper), you will see the patterns emerge: oil and filter change, engine and cabin filter changes, brake inspections and so on. You can then just extrapolate as far as needed. The only exceptions I think, and these are noted in the Toyota document: are coolant changes, subsequent changes are at half the interval of the initial one.
    Here's an example I did for third gen, based on US schedule, but I'm too lazy to do it again for second gen :).
  4. JC91006
    16,889
    8,625
    probably the same for 2nd gen
  5. Mendel Leisk
    42,096
    Or very similar. 2nd gen oil changes every 6 months or 5000 miles? Funny thing is: graph format is very likely how the schedule is first laid out, and then they convert it to this cumbersome event-by-event list format.
    (I'll crack and make up a 2nd gen graph, shortly...)
  6. JC91006
    16,889
    8,625
    2nd gen was based on the assumption of Dino oil changes, if you go synthetic, I think the schedule would be the same.
  7. Mendel Leisk
    42,096
  8. Mendel Leisk
    42,096
    Here we go, 2nd gen schedule. Please proofread, and if you see any clangors, lemme know:
  9. athas17
    Los Angeles
    2019 Prius
    Thanks. I would have to extend it, since mine is at 126k miles.
    I noticed on your chart that the 2 air filters are suggested to be changed every 30k miles. But every time I go in for an oil change (5k), they suggest I put in new ones. I do those myself, and at every 5k they are filthy. ??
    BTW, today it's suddenly in the shop for an inverter water pump. Very expensive.
  10. Mendel Leisk
    42,096
    Check my chart against the Scheduled Maintenance Guide published by Toyota, I'm hopefully just transposing that correctly. You can download by googling Toyota Tech Info, and go to the Manuals section. There's no mystery: Toyota spells out when to do all this, it's just a somewhat awkward event-by-event format. Also, take the filter recommendations with a grain of salt: at the recommended change interval, check them yourself and make a judgement. It really depends on your environment.
    I'll attach a pdf of it too, but again, if you're missing any books, you can download at the above link.
  11. Alain D
    Alain D Junior Member
    28
    Santa Cruz, CA
    Thanks for the table! The only thing I'm not sure about is they list replacing ATF and front differential oil at 60k ONLY in the towing/heavy loading case... doesn't say when do it at regular schedule (as if never) within that 120k printed schedule!
  12. Mendel Leisk
    42,096
    Yeah responded to your other posting. :)
  13. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1st replacement should have been done no later than 30K miles. Then REPLACE every 60K miles. Read: Transaxle oil, recent analysis | PriusChat
    In the USA, Toyota list the transaxle fluid as a "Lifetime" fluid: top off as needed. In case you don't know already, NO LUBRICANT LASTS FOREVER. Toyota's definition of "Lifetime," will be very different than a consumer's. I would not be surprised if Toyota views the service life of a Prius as 10years/150K miles, even though many function well beyond those years/miles.
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    The worn out lubricant that kills the car was indeed a life-time fluid! :eek:
  15. Mendel Leisk
    42,096
    FWIW, while Toyota USA says nothing about brake fluid, Toyota Canada now says to replace it every 3 years or 48K kms, whichever comes first. I guess I'm just trying to illustrate the gulf, between two Toyota entities. A few years back Toyota Canada didn't say anything about brake fluid either.
  16. padroo
    padroo Senior Member
    2,763
    2,253
    I hate general terms like lifetime.
    At the moment I am in the process of replacing lifetime shingles on my house that lasted only 19 years.
    They prorate them and give you chump change back if they don't last. I am looking at $18,000 for a new roof that should of lasted a "Life Time".
  17. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Got mine back from the 150k service today. In addition to the chart I had the PCV, brake fluid and coolant changed. Overkill but I went with a tuneup including new spark plugs too. Recently we put on new tires, new shocks and struts and had the wheels aligned after I hit a coyote carcass on the freeway. Next up is a full Prolong hybrid battery conditioning in June.
    We're heading out on a coast to coast to coast (West to East to Great Lakes and back) trip July 1 and I want to be as worry free as I can be about the car.
  18. Tague Zachary
    Tague Zachary New Member
    Los Angeles
    Thanks for posting! I se that the spark plug change is recommended here at 144k miles. I've ween elsewhere that iridium spark plugs should be changed around 100k. Do you know why your recommendation is so much higher? Thanks!
  19. Mendel Leisk
    42,096
    I’m not recommending, just transcribing the regular Toyota USA schedule. the California interval for plugs is significantly longer.
    this is all available in Toyota USA’s Warranty and Maintenance Booklet, which comes with the car, and pdf version available at Toyota Tech Info. It is mind-numbing event-by-event format, which motivated my spreadsheet translation.
    #19 Mendel Leisk, Feb 22, 2024
  20. CliffordTheBigRedPrius
    Washington, D.C.
    Here in 2024 to thank you for posting this! Was just about to try to do the same thing myself for my 2nd gen that just hit 160K in anticipation of finding a new mechanic in my new area :)
