scheduled maintenance required for hybrid cooling system
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DragonFax, Aug 19, 2017.
  1. D_n_D
    D_n_D Junior Member
    42
    Auburn, CA
    2013 Prius v wagon
    For hybrid cooling parts. Sounds to be the fan. Atleast by guessing.
    I have a V and still no clue where mine is. And I'm sure it needs cleaning.
  2. KCRed
    KCRed Junior Member
    Kansas City
    2016 Prius c
    I had this message once.. turned out I had stuff on the floor of the back seat blocking the vent.
    Mendel Leisk and ztanos like this.
  3. DragonFax
    DragonFax New Member
    Just a follow up to say thanks, and to confirmed that was the issue. Just a dirty fan. It was easy to clean out, and the message hasn't returned. I can sleep easily at night. Thanks all for the help. This would have been so much easier if I had just taken a snapshot of the message to begin with.
    LnG, ztanos, Raytheeagle and 2 others like this.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Thanks for the update. You posted this message and I've seen it a few other times on the forums since... so it's good to know the fix. :D
  5. ShaAnn
    ShaAnn Member
    94
    42
    2014 Prius c
    Great video...I vacuum my fan often and NEVER put items in front of the fan....
  6. John in Vermont
    John in Vermont Junior Member
    50
    22
    Rochester, Vermont
    2018 Prius c
    The battery cooling system is just the vent fan and grill. Clean the grill and check to see if the fan is working. If the grill is clogged cleaning it out will solve the problem. You may need to get the trouble code cleared but it may clear itself once you clean the fan and grill.
