Scheduled Timer for plugin charge only shows finish time
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenp11, Jun 17, 2015.
  1. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    After my 25k service it seems the timer scheduler when the square button is pressed/held flashes at 7am. When i press the H button the hour advances to 12am then closes. I want to start the charge at 12am and finish at 5AM. The timer windows closes when i move the finish hour to 12am and then my regular clock hour changes. Does anyone know if this is a problem or am i doing something wrong? It used to be when i pressed/held the timer button the start time would show at 12 am and after setting it would go to the finish hour
    #1 kenp11, Jun 17, 2015
  2. PriusInParadise
    180
    91
    Hawaii
    You can set a start time OR a finish time, but not both.
  3. mrbigh
    3,686
    699
    Long Island, NY
    DITO
    52,888
    tritto.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    It took me quite a while to figure this out. Unlike pretty much all other consumer devices which have timers, the PiP does not implement a start/end interval model (turn on at the start time, turn off at the end time). Instead, you can set either the time when charging will start, and it will stop when charging is complete. Or you can set an end time, and it will start charging at the time when it thinks that charging will be completed by the specified end time. Not sure what drug the engineers were on when they came up with this absolutely counter-intuitive behavior.
    PriusInParadise and bisco like this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    Cannabis Japanica ???
  7. kenp11
    74
    Orange
    2014 Prius Plug-in
    The behavior is different than when i first got the car. It allowed me to set start time first then finish time. I will try setting start time again and see if it makes a difference
  8. scrappy
    scrappy Active Member
    125
    309
    Orange County, CA
    2014 Prius Plug-in
    You can set both the start and finish times.
    But, you can only activate one of them.
    If you select "start" then charging will start at that time. If you select "finish", charging will start approx 3 hours earlier than the finish time you had set.
  9. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    The Japanese have severe punishment for possession of cannabis. As in years in prison for a few grams.
