Schematic of Gen 2 hydraulic brake system
Discussion in 'Gen 2 Prius Main Forum' started by Robert John, May 17, 2026.
  1. Robert John
    Robert John Junior Member
    64
    Montreal, QC
    I couldn't find a complete hydraulic brake system schematic in my shop manual (just the individual brakes), so when I went to the Toyota parts catalogue [https://catalogs.ssg.asia/toyota/?lang=e...etc. etc.] I get "Invalid SSL Certificate." Sooo... it appears that trusty site has moved.
    Q1. Does anyone know where it's moved to?
    Q2. If it's NLA, does anyone have a schematic of the hydraulic brake system for a Gen 2?
    BTW: I searched the site, but came-up empty handed. If it's posted somewhere here, please LMK.
    FYI: Brake line leading to RHS rear brake is leaking before connection to flexi-hose that runs to brake cylinder... thus my search for hydraulic brake schematic & part numbers.
    Thanks!
  2. ChapmanF
    19,009
    There are a couple of different kinds of diagrams you might be after, for different reasons:
    • Schematic diagrams, which help you understand what's going on by showing a simplified view of what does what to what, unburdened by the complexities of actual location and routing in the car, what tubes and hoses go where, and so on. You find these in the New Car Features manual. I'm sure there's at least one copy around here on PriusChat somewhere.
    • Physical layout diagrams, showing where all the parts and tubes and hoses go, so you can identify pieces like individual tubes and hoses and get their part numbers.
    Here's that schematic—I knew there was a copy linked around here somewhere.
    But if you're after part numbers, I'm afraid you're going to want the physical layout. Toyota's own parts website used to be great for those diagrams, until apparently they decided too many well-informed customers were showing up at their parts counters, so they "fixed" it.
    I'm not sure where you'd go now for those. @Mendel Leisk has posted favorably about Amayama's site.
  3. Mendel Leisk
    42,330
  4. Robert John
    64
    Montreal, QC
    Thanks for the link... similar to the 'exploded' diags. I used to access through [catalogs.ssg.asia/toyota/etc....] Doesn't have a full hydraulic 'exploded' but does have a combination of flow charts & local 'exploded' diags. That helps a lot. (Looks like I'll have to have the entire line replaced from the rear flexi-hose mount all the way to the front master block on the firewall. Thank you!
  5. Robert John
    64
    Montreal, QC
    Thanks for the schematic... very helpful. It looks like I'll have to replace the entire hydraulic line from the back flexi-hose mount near the rear brake drum... all the way forward to the brake actuator 'block' on the firewall. Very helpful knowing it's not like most other cars I've owned where the two rear brake lines went to an inertia pressure control valve mounted nearby in the back. As mentioned, I have the Toyota Gen 2 Shop Manual, but could not find anything like that. Thank-you!... much appreciated!
  6. ChapmanF
    19,009
    If you got the repair manual from TIS, the New Car Features manual is also there, no extra charge.
    The NCF is the place for all the explanations and diagrams of what parts are what and what they are there for and how they do it, so the repair manual leaves that stuff out and assumes you've already reviewed it.
    Toyota Service Information and Where To Find It | PriusChat
