Scientists replicate plants' process to split hydrogen from water
Discussion in 'Environmental Discussion' started by Sufferin' Prius Envy, Aug 18, 2008.
  1. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Don't count out a hydrogen economy yet . . .
    "An international team of researchers led by Monash University has used chemicals found
    in plants to replicate a key process in photosynthesis paving the way to a
    new approach that uses sunlight to split water into hydrogen and oxygen."
    Monash team learns from nature to split water
  2. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    That'd be cool if they can scale it up.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is a neat process, and one that is not snake oil. The key thing to remember with this type of process is that it reduces the energy loss incurred when splitting hydrogen and oxygen, but does not liberate energy. To say this another way, this new process is a net energy consumer.
    Hydrogen used in this manner is like an electrical storage battery. It stores energy for reuse at a later time, but does so at some cost. Lowering the conversion cost makes the use of hydrogen more attractive.
    Perhaps the main application of this process will be to store energy at electrical production facilities. Large scale storage allows electric utilities to balance cyclical loads. Many now use pump storage of water to do this, but this new hydrogen process may prove to be more efficient.
    Tom
  4. dogfriend
    7,512
    1,188
    Carmichael, CA
    Can I put this in a mason jar and feed hydrogen into my intake manifold? :madgrin:
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Only if you put the jar on the roof of your car.
  6. dogfriend
    7,512
    1,188
    Carmichael, CA
    How about if I install a solar tube in the hood of my car? Would that work? :madgrin:
  7. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Only if you don't put it where the sun dont shine. :rolleyes:
  8. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    So to troll a bit here.... is it safe to say that perhaps GWB's vision of hydrogen may come true (referring to his state of the union speach)? :)
  9. dogfriend
    7,512
    1,188
    Carmichael, CA
    I don't think it is proper to use "GWB" and "vision" in the same sentence unless you are documenting the result of his optometrist exam.
  10. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    LOL!!! I knew the choice of words would be commented on. Hey, at least I abbreviated "GWB" when I did it. I didn't want to cause loss of "vision" when you saw the entire name written out in the same sentence. :D
  11. Sufferin' Prius Envy
    3,998
    Not if some of the Luddites here on PriusChat get their way. :p
    How could scientist possibly figure out a way to utilize this most abundant and clean energy carrier for our transportation and other needs? :rolleyes:
  12. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Well, FCVs still have significant hurdles to clear. This process is merely a way to create hydrogen. That doesn't make FCVs viable, it just makes the creation of hydrogen from renewable sources more viable. That's a good thing, but doesn't translate into a paradigm (pronounced para-dig-um) shift for the transportation sector. It could prove to be a great way to create dispatchable power from wind and solar and so it's very good news. It might be a necessary piece of the puzzle to realize phase one of Pickens' plan. Sod phase 2.
