Scoring on brake discs/rotors.
Discussion in 'Gen 4 Prius Main Forum' started by The Professor, Oct 3, 2019.
  1. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    If it's just your rear wheels, that could be your parking brakes.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    BAD advice, based only on that picture.
    NO....no warranty possible on brake wear in general.
    The real bottom line is:
    I think based on all that he SAID, that his rotors are perfectly normal.
    Most ALL will be shiny and many will show uneven groves due to uneven pads.
    Uneven groves is QUITE different than SCORING.
    52,854
    really? it seems you're the only one (n)
    alanclarkeau likes this.
  4. Striker325
    Striker325 Junior Member
    25
    24
    Los Angeles
    Vehicle currently has 28,000 miles. I believe something got stuck like debris on both rear rotors causing the uneven wear. It's not bad but visible and uneven enough to feel it as you run your finger on the rotor surface.
    I can take a picture and post it. My solution at the moment is just wait until the pads are worn out to get new ones and get the rotors then resurfaced.
  5. Mendel Leisk
    42,345
    No one's done a rear brake job though? That can screw them up; don't ask me how I know... :oops:
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    A fault with the ABS unit could be something that could cause all 4 brakes to be affected.
  7. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    I'm not noticing anything weird, such as friction noises, scraping noises, squeaks, etc. Fuel economy is normal. Discs are cold after a typical drive.
    They're less shiny this morning. I guess they just looked polished in the picture as they're recently been used quite hard.
    The only thing I've ever noticed (and it's been doing this side I purchased it) is that the brakes do let out a brief quarter second vibration/groan just as you're coming to a stop and I'm reducing the brake pressure to reduce the jolt, but I doubt that's the cause as it's it's probably only doing it for 1/8th turn on the wheels every time I come to a complete stop, and the brakes are being pressed very gently (barely pressed at all).
    Does anyone else's make that noise?
    #47 The Professor, Oct 8, 2019
  8. bisco
    52,854
    that might be the friction brakes kicking in around 6-7mph?
    without having other prius experience, its hard to know what's normal and what isn't
    ice9 likes this.
  9. The Professor
    598
    809
    UK
    Excel
    No it's at the very end of the friction brakes kicking in... Going maybe 0.5 mph. It's the brake pads vibrating against the discs, making a musical note.
  10. bisco
    52,854
    that doesn't sound normal, but may be due to the state of the rotors. or perhaps something defective in the calipers?
  11. Striker325
    25
    24
    Los Angeles
    Can you perhaps get it on video of the noise to get an idea. I'd recommend using compressed air and brake cleaner to remove any debris from all four brakes and apply a light coat of brake lubricant on the parts that move.
  12. The Professor
    598
    809
    UK
    Excel
    Here's a video of it. I'm deliberately releasing and activating the brakes in a way that produces the sound. As I'm pointing downhill your also hear the noise on release of the brakes. Or appears to be just the brake pads resonating against the discs. It only happens if I press the pedal just hard enough to make contact.
  13. The Professor
    598
    809
    UK
    Excel
    imgur DOT com/a/8Jrz6SC
    ...Looks like the website breaks the URL.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Of those who have commented maybe.
    But that does not necessarily make it wrong.
    More information is needed.
    Wild guesses usually aren't really helpful.
    Yes, really.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    That does NOT by itself indicate a problem.
    Many/most/all disc rotors will display some rippling of the surface as they wear.
    That is because of an uneven composition of the pads.
    In general, the better the pads, the less rippling.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    You are just FULL of bad advice on this subject. :(
    If you have a light enough touch with your foot, you can make the disc brakes on almost ANY vehicle squeal or chatter slightly when just barely moving.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    That doesn't sound normal to me, it may be that the pads are glazed too.
  18. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Mine had no ripples or grooves at 300K miles on my gen II prius. I just replaced the original pads, front rotors and rear drums.
    bisco and hill like this.
  19. Mendel Leisk
    42,345
    I'm seeing/hearing it ok now, and that sounds fishy. Maybe mechanic from the dealership can test drive?
  20. hill
    9,038
    of COURSE you didn't have such dynamics. Anyone with relatively moderate breaking skills can keep Prius rotors/pads for an easy 6-figure amount of miles. But there's no point in giving experiential advice really - after post #42 - as there will always be somebody here that will countermand 38yrs experience in the electro/mechanical aerospace field, w/out so much as a fraction of a basis why they would make such irrational notions.
    Rotors with visible grooving as in the pic above - means that they are likely as deep as .015" which in some states, by law you have to either resurface or junk 'em. There are lateral irregularity regulations as well in many areas. The batch of metal (alloy) may be flawed, or incorrectly heat-treated. That may be why on the other thread, Toyota was quick to do a replacement on another's Prius regardless of warranty.
    #60 hill, Oct 8, 2019
    sorka and Mendel Leisk like this.
