Screeching After Changing Brakes and Rotors
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by xjoehallx, Jan 29, 2023.
  1. xjoehallx
    xjoehallx New Member
    Spokane, WA
    I recently installed new front pads, rotors and calipers on my 2006 Prius. I used a TRQ brand kit from 1A Auto. The install went quite well, but shortly after the car started making a horrendous high-pitched whine/whistle noise while driving (not while braking!). The noise is clearly coming from both wheels and is near constant when the wheels are rotating (braking actually relieves the noise). I've driven it about 200 miles and it hasn't really changed.
    Any advice on what's causing this?
  2. Tombukt2
    Tombukt2 Senior Member
    13,697
    2,479
    Durham NC
    This is in the front? Put the front end up off the ground ready the car Heck even put it in drive with the front end off the ground and the wheels hanging is the noise present while the wheels are just spinning going nowhere step on the brakes while you're doing this do you hear anything when you step on the brakes lightly step on the brakes and allow them to drag on the rotors a little bit there's the noise start stop nothing?
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,316
    932
    Monument, Colorado USA
    Yep something isn't right in there. You're going to have to get both tires off and redo those brakes. Do the new pads have the little low-pad warning tabs and are they in the right spot? Did you remove and clean then relube the caliper pins? Did the shields around the calipers get moved and is now touching stuff as the tire spins? Get it up on jacks and then spin the wheels and try to determine where the noise is from. If it's the new pads, you may try putting a very small amount of brake quiet stuff on them.
    My worst brake job was on an old Suzuki my son-in-law had....had to re-do it 3 times before it wouldn't make squeeling...but keep at it, you'll find it.
  4. xjoehallx
    Spokane, WA
    Thanks for the input. I think the noise is the same it would make if your pads were worn down and your wear indicator tabs were rubbing. My guess is the problem is around there. I'll tear into it and report back.
  5. xjoehallx
    Spokane, WA
    Well I got the noise to stop, however I forgot to disconnect the battery this time. Now I have all the brake warning lights on the dash. I tried the paper clip trick but it didn't work. Any advice on getting these to go away?
  6. ColoradoBoo
    1,316
    932
    Good job fixing it! For the codes, if you don't have a good scanner to clear them, try disconnecting the negative battery terminal and waiting for a bit then reconnect. If that doesn't work, check with your local car parts store and see if they have a scanner that can clear the codes.
  7. ChapmanF
    18,820
    ColoradoBoo likes this.
