Screeching fan belt type sound?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fuji, Mar 15, 2020.
  1. Fuji
    Fuji New Member
    New Brunswick, Canada
    I’m wondering if anyone has any idea what could be causing a noisy fan belt type sound coming from the engine area when accelerating at certain speeds(I know the Prius gen3 doesn’t have a belt).
    I’ve searched around the forums and the closest thing I could find is potentially a coolant hose clamp rattling behind the engine may be causing this?
    If anyone has dealt with this before I’d love to hear what was done to fix it.
  2. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    I dont hear much from the video.
    I just dont think you could hear a loose clamp while driving.
    Only thing I can think of is a heat shield that is rattling.
    Or perhaps brake rotor shields.
    All of your fluids look at ok levels and caps/dipsticks are there ?
    Might as well check the hose clamps to be safe.
    Raytheeagle likes this.
  3. Fuji
    Fuji New Member
    Yeah it's hard to hear in that video because I've got some winter tires on at the moment that make the overall sound in the car loud, but it's the high pitch sound in the background. I'll try to see if I can see a heat shield that's loose.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Is the prop rod for the hood secured in its place?
    I had that happen once after dealer servicing:cool:.
    But @dig4dirt 's suggestions above are other likely causes(y).
