Screen Glare
Discussion in 'Prime Main Forum (2017-2022)' started by bear15, Aug 2, 2017.
  1. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    I am experiencing some noticeable screen glare in the Prime Advanced when it is sunny out. Any quick solutions?
    MasterPri08 likes this.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I tinted my windows and problem was solved for me.
    #1 in Easley,SC
    bodgm and bisco like this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, change your car model in your profile, should eliminate the glare (mine mostly:cautious:)
  4. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    I don't have a Prime, but I have the 11.5"(?) screen. Even before window tint, it never showed any glare. What is so different about the Prime's screen? Many threads and complaints about glare.
    (Tint is great. But I can't see anything at night. :eek:)
  5. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Thanks for the information. How do I change the car model and what do I change it to"
    priuscatprimeguy likes this.
  6. priuscatprimeguy
    2,730
    2,640
    took me a minute but I found out how, click on your profile and the profile page will drop down, then click on personal details personal details.JPG
  7. priuscatprimeguy
    2,730
    2,640
    I assume you have a Prime, so change it to that, you should be able to select Plus, Premium, or Advanced:D
  8. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    I am confused-- sorry. How will this help eliminate the screen glare in the car? These look like steps to do on this forum.
  9. bisco
    52,763
    you can get the big screen in the lift back?
  10. priuscatprimeguy
    2,730
    2,640
    you're just not trying hard enough:D
  11. Tideland Prius
    16,668
    Alright stop confusing him.
    As for glare, it is a problem for most cars unless it's deeply inset (like on some Lexus, BMW and MB models but those aren't touchscreens).
    I'm not sure why they went with a glossy finish for the screens. My 2010 has a matte finish and it mostly works (except when the sun comes through the moonroof or at the right angle through the window. In the case of the moonroof, I just close the sunshade). Hopefully someone can come up with an accessory like a screen protector that will reduce the glare.
    priuscatprimeguy and Nic Steussy like this.
  12. priuscatprimeguy
    2,730
    2,640
    sorry:cry:
  13. CoastRider
    305
    397
    My mistake. 7" diagonally. Maybe it appears larger because of the border around it? It has glare on it now because the door was open during this pic. But I honestly don't recall any bothersome glare while driving, even before tint. The Prime has that nice BIG screen. It's beautiful. Sorry to hear about the glare.
    #13 CoastRider, Aug 2, 2017
  14. stevepea
    stevepea Senior Member
    535
    581
  15. Mark57
    2,945
    2,740
    OK
    The suggestion to changing your forum profile above was a tangent to your original question and obviously had nothing to do with your physical car. Your Priuschat forum profile says you are driving a 2015 Prius III. Since you were asking about and appear to "now" own a Prius Prime, they were suggesting you update your forum profile to reflect this. When a member asks questions on the forum, before we answer, we typically glance at the user's profile to see what they are driving. It helps us give you better answers. So while is a tangent, is is mildly relevant and is for your benefit. I hope this helps.
    dalcon95 and priuscatprimeguy like this.
  16. bear15
    bear15 Member
    168
    36
    Suburban Chicago
  17. priuscatprimeguy
    2,730
    2,640
    hey!:mad: I resemble that!:p
  18. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Tinted windows.
    dalcon95 likes this.
  19. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    :ROFLMAO:
    I'm glaring pretty good myself... at all you Primers.
    being in the midwest and not having decent access to a prime :cry:, I don't know if you can do what I do. On my 2014 there is a slot that runs around the bezel of the screen. It's wide enough to jam in a couple of pieces of cut-up shoebox cardboard. I made them small enough I can still use the buttons but they throw shade on the screen. Easy enough to stick in or take out as needed. I'm on the lookout for plastic pieces or something more durable than cardboard.
  20. RuthlessTactics
    RuthlessTactics Junior Member
    Chicagoland
    [DISREGARD]
    #20 RuthlessTactics, Feb 5, 2018
