Screen Problems/Solution?
Discussion in 'Gen 2 Prius Main Forum' started by Peabody214, Jul 18, 2007.
  1. Peabody214
    Peabody214 New Member
    On sunny days, the back-up camera's screen picture is almost non-existent. Is this normal? If it's cloudy or at night, I can see it fine. Do I need to adjust something? Also, is there a recommended product for clearing up those pesky fingerprint impressions from time to time without damaging the screen?
  2. priussoris
    priussoris New Member
    1,005
    Some have bought a "hood" to block the sun's glare We incorporated a hood into our dashmat that works great.
    As for cleaning the screen do it when the car is off, otherwise you may re-set your mpg and miles also may activate a hidden easter egg. Also there are screen protectors on ebay, we bought one seems to keep the prints off too and saves the screen for resale purpose also
    Use Ammonia FREE window cleaner works great. and then a micro-fiber cloth
  3. rsvogt
    rsvogt New Member
    I just experienced the same thing with the dark screen. Are you driving with your headlights on? This will dim the light so it can be seen better at night. But during the day . . . .
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(priussoris @ Jul 18 2007, 07:44 PM) [snapback]481294[/snapback]</div>
    You can also turn off the screen before you clean it. An LCD cleaning kit for computer screens works well.
    Tom
  5. SweetPri
    SweetPri New Member
    33
    Nashville, TN
    I turned the light dimming switch all the way up and it made all the difference.
  6. Peabody214
    Thanks to everyone who replied. I did turn up the dash lighting and that helped and I'll check into the cleaning options for the screen. Thanks again. Peabody214
  7. ohershey
    ohershey New Member
    632
    There is also a seperate setting for "day mode" for the MFD screen, which is only activated when you:
    1. Turn the headlights on
    2. Roll the dash dimmer all the way up until it "clicks"
    Then you can go into the MFD settings and adjust the brightness/contrast for day mode, which should help.
