Screw in the tire
Discussion in 'Prime Main Forum (2017-2022)' started by Gokhan, Jan 22, 2020.
  1. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    "...On a couple of our previous cars, boosted pressures very significantly improved the tread wear patterns. Though those cars were of the same era and had the same 26 psi recommendation label...."
    A few years back the manufacturers started putting on placards for tire inflation pressure that was realistic. The old 26 psi was for comfort and not the best all around. Current tire pressure recommendations are likely the best in most circumstances. It's always a compromise. Higher pressures do decrease traction.
  2. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Yes, I'm aware. Unfortunately winter in Colorado has a very wide range of temperatures in the winter. The temperature can literally change 60 degrees F or more in 24 hours. (Storm Recap: Potent storm delivers promised first snow and frigid temperatures – BoulderCAST) Not much I can do about it. If I had my own pit crew maybe I'd change out my tires for the most appropriate type everyday.
    My post about tread wear is here. GET YOUR DEDICATED SNOW TIRES NOW !!! | Page 10 | PriusChat
    This season the front tires don't seem to be wearing excessively, and the weather isn't much different. The only difference I can think of is pressure.
  3. Trollbait
    12,806
    I know of the snow tire rubber, because a friend used to live in Colorado.
    Pressure is a factor for traction, but could simply that you have adjusted to the Prime better in that time. Tire age might be another factor. rolling resistance is worse with new tires in part because of the effect the mold release agent could change the top layer of rubber. Perhaps it has a negative effect on the rubber's grip.
    "The Prime in EV mode seems to be a tire shredding machine."
    It's that instant torque. Tire manufacturers are starting to make EV tires that hold up to it better.
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Blizzak recently (this year?) came out with the WS90 that's supposed to be much longer lasting than the WS80 (which I have). They probably developed it partly because new cars have more power and torque than ever before. The WS90 isn't specifically designed for EVs from what I can see, but it sounds like it would help.
    I have the same torque this year, and I still floor it all the time, but this year I'm not accidentally doing front wheel burnouts if I try to start to quickly.
    Mold release could be a factor, but that should be worn off in the first few hundred miles. I wonder if maybe I slightly rounded over the edges of the tread blocks, which then made the tire more slippery? I rotated the tires that were on the back last year to the front this year, so they had a more gentle start to their lives.
    I've it said before; I still think the traction control is poorly programmed and allows too much wheel spin. Assuming they have tight feedback control of MG2 speed (which they probably need to power the motor with the inverter), they should be able to keep the motor speed from increasing unreasonably quickly, as it does when one or more wheels lose grip.
  5. Trollbait
    12,806
    They might be using ABS to watch for wheel spin.
    It can take thousands of miles before fuel economy on new tires reach what it was previously. Remember, the rubber is being heated and is under some pressure, so the compound could be diffusing in further than the surface.
  6. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    They are, but it could be better. It sounds like older generations were criticized for cutting engine power when a wheel started to slip, making it hard to accelerate. To some extent ABS is part of the problem because it can only relatively coarsely brake a slipping wheel to send power to the wheel with traction. But if that braking wheel hits a patch of pavement with more traction, it will slow you down when you're trying to accelerate.
    The 4th gen apparently allows more wheel spin, but wheel spin doesn't accomplish much. I think if they controlled the speed of the motor, the slipping wheel would never get going too fast, and a lighter amount of ABS could be used without shock loading the drivetrain or making it hard to accelerate.
    With a non-hybrid, the engine has more momentum than an EV motor, so it spins up a little slower. I think they could electronically simulate very high momentum in the motor by not letting the speed increase much faster than the car can reasonably accelerate.
  7. fuzzy1
    10,687
    Which year was that? All my household's cars are older than just a few years.
    Yes, it is a compromise between numerous conflicting goals. And comfort is still heavily weighted into that compromise. But numerous drivers don't place the same relative weighting on those various goals, so naturally their personal preferences lead to different results.
    The cars we have rented in Europe had multiple choice tire pressure labels, depending on the use. I looked for those labels because a number of PC members had previously mentioned them. But the U.S.-market labels are simplified, as if American drivers are less able to make such judgements.
    Do you have some good references for that?
    A previous poster who referenced a technical study to back up this assertion, turned out to be misreading the study's nomenclature, as discovered by a quick skim of the glossary section
  8. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I'll be the reference on this.
    As a long time SCCA racer, higher tire pressure can & is used to decrease traction on one end of the chassis.
    Rob43
  9. fuzzy1
    10,687
    Can you link your technical publications on this? So that I can review the studies and figure out how they apply to ordinary non-racers?
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Sorry no.
    It was something taught to me a million years ago at the track, then I used it successfully going forward in racing & street use.
    I will tell you this is the exact reason I always run my Prime with "roughly" ~3 psi more in the rear. Currently I'm at 38F & 41R, it simply helps to get rid of some of the built in understeer.
    Rob43
    Tips likes this.
  11. fuzzy1
    10,687
    I've seen technical reports from studies that actually measured rolling resistance, and hydroplaning onset speed, vs inflation pressure. They gave me a better technical understanding about what is happening, and the magnitude of the changes.
    There are at least two camps on the traction issue, hypermilers claiming improved traction at higher pressure, and another group (e.g. racers and 'conventional wisdom') claiming a reduction. But I've seen no studies measuring it, so don't know which group is correct, or if both may be partially right within their particular domains of interest. Thus I also have no clue about the relative magnitude of any traction changes vs pressure, whether or not it significant enough to be concerned about.
    Personally, I don't care about dry traction, because that is the best case. I live in a wet climate, so hydroplaning and wet traction are the important factors in my environment. And snow and ice in winter. If one takes care of them, the worse and worst cases, and drive as if they are always present or just around the corner, then the dry traction case takes care of itself.
    #31 fuzzy1, Jan 23, 2020
    Trollbait likes this.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Another myth.
    It depends on:
    What tires and what vehicle AND higher than WHAT.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    You should try selling that statement to Auto-X'ers... OR better yet someone like me.
    Tuning the chassis "on the fly" with tire pressure works.
    All of these simple rules trickle down to our FWD Prime.
    Rob43
    Tips likes this.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    SIGH.
    You can't state "rules" without also stating the context.
    "higher" is not better......unless you know "higher than WHAT"........and applied to WHAT.
    And as is often the case, you can't apply racing information/design/parts/rules to a street car without a careful explanation of how and why.
  15. Mendel Leisk
    42,271
  16. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Lol, yep.
    But sams on a flyer.
    Rob43
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Go ahead. Throw a few more insults.
    It was not ME who took the thread on a side road.
  18. Gokhan
    Gokhan Senior Member
    6,698
    2,651
    Paramount CA
    Update:
    I went to the dealer to have the tire installed, which was ordered from the warehouse the day before. I told the service advisor one more time to make sure the Euro-metric Toyo A41 is installed, not the P-metric Toyo A29. She assured me. I waited for an hour and a half and I got the text message saying my car was ready.
    I went to pick up my car and checked the new tire before I drove away. Of course, they installed the P-metric Toyo A29, which is the wrong tire for my car.
    I went back to the service advisors. It took them half hour to figure out what was wrong. They initially thought the warehouse sent them the wrong tire or the tire could have been superseded. It turned out that they had ordered a bunch of A29's and A41's, and they all had my name on the labels. The parts department handed the mechanic out the A29, even though I asked the service advisor specifically to put on the A41, but the communication broke somewhere.
    After another half hour, they removed the A29 and installed the A41.
    The cost was about $135 including mounting and balancing, not a bad deal given Tire Rack sells them for $100 + tax.
    Finally it's as good as new with the identical OEM tires with no holes on all four wheels! :)
  19. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Wow...
    I'm glad you got it all sorted out, but hearing stories like this makes me glad that I plug my own tires in 5 minutes for less than $5 dollars.
    Rob43
    #39 Rob43, Jan 24, 2020
  20. Gokhan
    6,698
    2,651
    Paramount CA
    Regarding Euro-metric vs. P-metric and if high pressure is OK:
    I had a 1985 Corolla, which specified the Euro-metric 155SR13, 165SR13, and 175/70SR13 tires. Recommended tire pressures were something like 28, 28, and 27 psi, respectively.
    I bought the OEM repair manual, which also specified the P-metric P155/80R13 tire, in addition to the three Euro-metric tires specified on the glove compartment and in the owner's manual. Guess what the specified pressure for the P-metric P155/80R13 was. It was 36 psi, which was the maximum cold tire pressures for tires at that time and considerably higher than the 28 psi for the Euro-metric 155SR13. They must have thought that the P-metric tires are not as reliable or as good with carrying loads and tried to make up for it by recommending the highest pressure the tire can take.
    Moral of the story: I think the tire-pressure recommendations by OEMs are fairly random. OEMs are mostly concerned with ride quality and tend to recommend pressures lower than optimal for handling, tread life, and real-life fuel economy. I don't think higher pressures wear the suspension quicker, increase road-hazard-damage risk, make tires wear unevenly, etc. As long as you stay below the maximum specified on the tire wall or you don't experience handling or ride problems, it's probably OK, and you actually get an extra marking of safety. However, you need to remember to bleed the tires if you set the pressure at the maximum and then the ambient temperature increases more than 10 °F. Another risk is if you have a gauge that underestimates the pressure, it could cause you to exceed the maximum pressure.
