Screws in my Tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Montgomery, Dec 21, 2016.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    So, I found my passanger rear tire had a screw in it along the side edge and the front passanger tire had one in the top. Had to have the front one fixed and the rear one replaced. And yes, as a result, I purchased two tires so the wear would be even. So, at nearly 19,000 miles, I have two new rear tires. I have to say this car still rides like it is brand new.
    Raytheeagle likes this.
    49,500
    bummer. did you have to use the spare?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I just had a screw in my driver rear tire last month:
    Found it when the TPMS light came on as the tire was holding at 20 psi. Was able to air it up and drive it to Costco and they plugged it for free. Tires have 25k miles on them. 3rd screw I have had in my tires in the last 3 years. Mostly work caused as the trucks carrying supplies don't always have them secured properly:(. They have finally resurrected the street sweeper so it is improving(y).
    Where'd you get the new shoes at?
    Montgomery likes this.
  4. Montgomery
    2,254
    2,238
    Orange County, CA
    I got mine at Just Tires. Been going there for 20 or so years.
  5. Montgomery
    2,254
    2,238
    Orange County, CA
    Nope, just filled it up and drove 2 miles.
  6. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Free mount, balance and rotations?
  7. Montgomery
    2,254
    2,238
    Orange County, CA
    Not on this set, since they were the original tires. But the two I bought are warranteed to be plugged (if not along seam) or replaced.
  8. Mendel Leisk
    38,729
    That's the perfect place to get a puncture, near the middle of tread. Every time I get a puncture, two so far with this car, it's near the edge; tire places are reluctant to repair, because the curve into sidewall has commenced, their internal repair won't seat properly.
    That tipped me to get an external plug repair kit. Both my punctures were about an inch (at most) from the tread corner, plugs have worked fine. Like the red dots:
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    2011 got a screw in the lower side wall and had to replace the new EP20 with a 422Plus.
  10. Michelle W
    Michelle W Junior Member
    Northern IL
    I got 3 in one tire, probably at the same time. (Not sure where I got them at..) All were able to be plugged and I've put another 15k on it.
    Montgomery and Mendel Leisk like this.
