Scuff mark
Discussion in 'Gen 3 Prius Main Forum' started by vietalogy, Jun 1, 2013.
  1. vietalogy
    vietalogy Junior Member
    23
    Grand Rapids, MI
    I got my Prius two almost a month ago and just noticed this scuff mark. Anyone know the best way to remove it without harming the paint?
    Sent via Galaxy S4
  2. bubbatech
    bubbatech Member
    153
    60
    Alabama
    Meguiars Scratch X works very well in removing blemishes. It has solved a number of issues for me.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Ditto, wife rubbed up against pole. Spent $5 for some wax kit or whatever. I had zero confidence it would come off. The paint had come off onto the pole. Whats the point? But I was wrong and it litereally "buffed right out."
    vietalogy and 2010PriusIII like this.
  4. vietalogy
    23
    Grand Rapids, MI
    Thanks, would auto stores like auto zone carry this?
    Sent via Galaxy S4
  5. 2010PriusIII
    2010PriusIII Member
    69
    24
    Boston, MA
    2018 Prius Prime
    Just did a google search and meguirs scratch x shows up for autozone, Walmart, target, and amazon. I agree with bubbatech, it's good stuff.
  6. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Meguiars M105 also works really good. Not sure how it compares to ScratchX.
  7. bubbatech
    bubbatech Member
    153
    60
    Alabama
    If you do use the Scratch X, be sure to wax the area afterward. The scratch X is a very mild abrasive that works on the clear coat, so it removes the wax. It is also good for things that slightly etch the clear coat, You can't remove such blemishes with a clay bar. Scratch X is the only thing I have found that will remove them and yet leave an excellent shine.
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Be real careful when rubbing out the scratch on the curve of the fender. The shape of the curve results in extra pressure, resulting in faster cutting. That makes it easy to go through the clear coat, then you have problem.
  9. BZzap!
    BZzap! Senior Member
    1,607
    877
    It appear to be simple paint transfer. The Scratch X is good to use as it is almost the same product as 3M "Fineness-it II" professional finishing material. P/N -05928. It is specifically for clear coat finishes.
  10. SFR-DSR-44
    SFR-DSR-44 Junior Member
    57
    Milpitas, CA
    Exactly what those above are saying. The old tale of "I cut it again but it is still to short" applies here. Go slow with minimal pressure....it is always easy to do a little more and you want to remove as little of the "good stuff" as possible.
  11. bubbatech
    bubbatech Member
    153
    60
    Alabama
    Agreed. "minimum necessary" is the best rule.
