Sea foam or Motor Flash in Crankcase to flash sludge
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Jun 11, 2020.
  1. Tekken
    Tekken Member
    250
    74
    Los Angeles, California
    Per Sea foam instruction, 1 ft oz / quart of oil and engine can be run 100-300 miles before oil change.
    Motor flash, 1 quart per crackcase oil and flash 5-10 min on idle speed and Drain oil out after 5-10 flash. CAN NOT drive your.
    I can tell my 2013 prius has alot sludge since my last EGR cooler clot up on clearing and NO oil catch can install yet.
    Comments, questions and your experience are welcome.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    It is almost NEVER a good idea to put "solvents" into your crankcase as a "preventative" measure.
    Whatever sludge is stuck to non-working parts is NOT likely to cause a problem.
    If you loosen it so that it starts moving around......then is IS likely to cause a problem.
    Solvents mixed with the oil reduces it's lubricating ability.
    Does that sound like a good idea to you ??
  3. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Yes, another seafoam post!!! Looking forward to all the replies :D
    #3 Grit, Jun 11, 2020
    Raytheeagle likes this.
  4. Tekken
    Tekken Member
    250
    74
    Haha... how do you clear sludge in a 100K miles engine?
  5. Tekken
    Tekken Member
    250
    74
    No Solution to clear sludge inside engine?
  6. ASRDogman
    ASRDogman Senior Member
    5,908
    3,167
    What kind of oil are you using that you have sludge at 100,000 miles?
    Have you never changed the oil?
    Drain the oil and then fill with 3 3/4 quarts of regular transmission fluiid.
    Idle for 15 minutes. Then drain and replace oil filter and fill with 0-20w synthetic oil.
    Taking it completely apart is the best way, and really the only correct way.
    Why would you think you had sludge?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Lots of flash's whatever that is.
    Sludge is caused by crappy oil.
  8. sam spade 2
    7,035
    2,783
    2017 Prius c
    In most cases it is TOTALLY unnecessary......because the places that it accumulates does NOT in any way interfere with proper engine operation.
    Of course, that is assuming that the engine has been treated to reasonably good routine maintenance.
    Bay Stater and ASRDogman like this.
  9. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Same, I'm confused that the OP wants to motor flash. You can only do that with electronic hardware which you flash the memory.
  10. Tekken
    Tekken Member
    250
    74
    I filled with synthetic 0=20w . but don't know what oil the previous owner used. Got it with 92K miles and now 99,700 miles now. It has changed oil 2 time since.
    Don't know Transmission fluid can clear sludge in the engine.
    No oil catch can, oil in bottom of Throttle body and oil on Manifold.
    #10 Tekken, Jun 12, 2020
  11. ASRDogman
    5,908
    3,167
    You haven't said how you know there is sludge? Probably not.
    You could check the vin number with Toyota and see if they changed it.
    If the car, and engine compartment looks okay, they probably took care of it and
    did have it changed.
    When you changed the oil the first time how did it look? Unless it came out super black,
    you are probably okay. When you took the oil filer cap off, was it clean inside?
    Just use the correct oil like you are, and you'll be okay.
  12. NewHybridOwner
    NewHybridOwner Active Member
    607
    279
    W. Michigan
    I know that a few decades ago on another continent I used flushing oil -- not an additive but a whole different oil that replaced the old oil and was then drained after running the engine for 10 or 15 minutes before refilling with the regular oil. It was most likely a Castrol or BP product, because those are pretty much the only brands I ever used. I remember it had a distinctive and not-unfamiliar smell, but I can no longer recall what -- wintergreen? I see Castrol Flushing Oil available in the UK, and in Australia a flushing additive called Castrol Engine Shampoo, but neither is on their US Web site.
    Last year I used BG Products EPR on a Pontiac Vibe (Toyota engine) with 160K+ miles, and the drained oil looked something like chocolate, so either it did get a lot of sludge out or it contains a compound that turns chocolate color when heated or mixed with regular oil. There had been no sign of sludge, nor was the oil unusually dark, when doing a regular oil change.
    I can't decide whether to try it on our 36K-mile Prius next oil change time.
  13. ASRDogman
    5,908
    3,167
    36,000 miles and you think there is sludge? Where are you getting this idea????
    As I stated, remove the oil filler cap, is it's not all nasty looking, you don't need to do anything.
    Except change the oil as usual.
  14. NewHybridOwner
    607
    279
    W. Michigan
    No, I am not imagining that there is sludge, but it's certainly possible that there is a coating left on non-bearing surfaces, which it surely would not hurt to remove. And if the oil plus BG EPR comes out looking like chocolate (as with the 166K+ mile Vibe), then perhaps the stuff really does just become chocolate-looking when it heats up or mixes with oil. Call it a scientific experiment.
    Threej and Jim Swart like this.
  15. sam spade 2
    7,035
    2,783
    2017 Prius c
    There is the flaw in your thinking.
    It really CAN "hurt something", especially if you make a mistake and don't do it right.
    OTOH, there really is NOTHING useful to be gained.
    Jim Swart likes this.
  16. ASRDogman
    5,908
    3,167
    You still have not answered HOW you KNOW there is sludge in you engine.
    Xray vision? :)
    Just because the oil looks nasty when it's drained, doesn't mean there is sludge.
    Ed Beaty likes this.
  17. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Oil is supposed to leave a film; if it didn't, moving parts would wear excessively until oil has started circulating after each startup.
    Oil is also supposed to hold contaminants in suspension, turning it dark and "nasty looking." That means it's doing its job. Leave it be and change it on the manufacturer's recommended schedule.
    ASRDogman likes this.
  18. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Clogged EGR caused crankcase oil to sludge? I have to know how you came to that conclusion.
  19. NewHybridOwner
    607
    279
    W. Michigan
    I specifically wrote "on non-bearing surfaces"; I was referring to a baked-on, typically orange-brown coating on, say, the piston rods or the valve-gear cover. I can't find any pictures now, but I know I've seen them.
    Not a few PriusChat members have praised BG Products' EPR. For their extended warranty (which I think requires the treatment to be performed by one of their authorized maintenance facilities -- which I was not intending to do -- and in fact they do not officially sell their products to end users), the EPR treatment has to be performed before the vehicle has done 100K miles and has to be repeated every 10K miles thereafter.
  20. sam spade 2
    7,035
    2,783
    2017 Prius c
    SO ???
    Just in this thread alone, several owners have said that you should NOT worry about general "sludge accumulation" inside an engine.
    And you should try to sort out what real experts say.......versus what self-appointed experts claim about the benefits of using "snake oil".
