Sea-level doom from Antarctic melting
Discussion in 'Environmental Discussion' started by tochatihu, Sep 23, 2024.
  1. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    I had hopes for Howard Dean also, I think he threatened to regulate the media? Then they exaggerated "the Dean scream" to make him look bad.
    Mark Twain is good
    Politicians and diapers must be changed often, and for the same reason.
    It's easier to fool people than convince them they have been fooled.
    Suppose you were an idiot. And suppose you were a member of congress. But then I repeat myself.
    If voting made any difference they wouldn't let us do it.
    Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
    I'm not as cynical as George Carlin was but he did tell the truth
  2. T1 Terry
    T1 Terry Senior Member
    966
    546
    I like that one, so true ..... Remember the tobacco industries effort they put into lying to everyone about the affects of smoking, then the cotton industry about the dangers of cannabis hemp? How many still believe the lies rather than accept they were fooled ......
    T1 Terry
  3. tochatihu
    tochatihu Senior Member
    9,962
    3,846
    Kunming Yunnan China
    2001 Prius
  4. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    When has seal level ever remained constant?
  5. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    At least half the time it was on the rise, and about half the time it has fallen.
  6. fuzzy1
    10,691
    It had been relatively stable for several millennia. The last time it was changing this rapidly was during the rapid glacial meltoff that marked the end of the last Ice Age. But then it was rising from a level more than 100 meters lower than today.
    #86 fuzzy1, May 20, 2026
  7. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    If this sounds like denial, it's not; but the carbon cycle is unsustainably out of balance.
    But it's foolish to try to make the climate static. It never has been in 4.5 billion years.
  8. fuzzy1
    10,691
    Who was aiming for static?
    The speed of this anthropomorphic climate change is the great concern, exceeded only by certain cataclysms such as asteroid impacts, and the exit from (but not entrance to) Ice Ages, or at least the most recent Ice Age. Over Earth history, it appears that most other climate changes have been far slower.
    Fast climate changes appear to be associated with mass extinctions. Biological evolution doesn't adapt nearly as well to these speeds.
    Trollbait and Mendel Leisk like this.
  9. Mendel Leisk
    42,306
  10. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
  11. Mendel Leisk
    42,306
    Whenever you quote me, my first thought is "what now...". You never disappoint.
    bisco and fuzzy1 like this.
  12. bisco
    52,807
    I'm advising our grandchildren to buy at altitude
    bwilson4web likes this.
  13. bwilson4web
    16,520
    Based on the slow rate, I would change to a minimum 100 ft above sea level. Future sea view property outside of hurricane surge range.
  14. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Doesn't look like a quote to me.
  15. ChapmanF
    18,994
    Post #90 appears to be a post, made by you, quoting Mendel.
  16. ColoradoBoo
    ColoradoBoo Senior Member
    1,346
    972
    Monument, Colorado USA
    I realized the "rising sea level" warnings were a load of horse manure when the "smartest President in history" (Obama) purchased an $11 million ocean-front estate in Martha's Vineyard.
    If he ain't scared, neither am I!!!!
  17. fuzzy1
    10,691
    CalTopo's map shows that house at an elevation of 7 feet. That is "high elevation" compared to places like Miami Beach and New Orleans.
    By 2050, which is beyond Obama's and my average remaining life expectancies (and right at Michelle's expectancy), the water level is projected to rise no more than 1 foot more, so he won't be losing enjoyment of that property during his able-bodied life, before needing to go into assisted living or a nursing home.
    By 2100, the high-end projections would have sea level lapping at the door mat, but the mid- and low-end projections still leave it usable. So his grandchildren are the ones to have first-hand concern.
    Plenty of people want to leave their grandchildren a better world, not a more-troubled world.
    #97 fuzzy1, May 21, 2026
  18. tochatihu
    9,962
    3,846
    2001 Prius
    "The last time it was changing this rapidly was during the rapid glacial meltoff that marked the end of the last Ice Age" quoting @fuzzy1
    see:
    Sea Level in the Past 20,000 Years | EARTH 107: Coastal Processes, Hazards and Society
    about half-way down shows that SLR occurred between about 15 and 8 thousand years ago. During those 7 thousand years SLR was about 1000 meters. Thus averaging 14.3 mm/yr. Current rate is about 4 mm/yr and increasing. Future of SLR depends on large chunks of Antarctica breaking off, or not, and when.
  19. fuzzy1
    10,691
    Typo alert: I think you mean about 100 meters, not 1000.
  20. bwilson4web
    16,520
    There are some Antarctic glacial flows ‘pinned’ by islands. Should sea level rise and unpin those glacial flows, we could see significant sea level spikes.
