Sea-level doom from Antarctic melting
Discussion in 'Environmental Discussion' started by tochatihu, Sep 23, 2024.
  1. tochatihu
    tochatihu Senior Member
    9,960
    3,845
    Kunming Yunnan China
    2001 Prius
    Ya 100 meters. Gotta watch those zeroes. Snowball Earth (happened very long ago) may have phase changed 1000 m of seawater.
  2. tochatihu
    9,960
    3,845
    2001 Prius
    Sea level rise comes from expanding volume of ocean waters by adding heat, melting continental glaciers, and detaching Greenland and Antarctica ice. Each of those has a current rate that should be in our earlier discussions. Only Greenland and Antarctica ice could provide large accelerations to SLR.
    A new constraint on Antarctic ice has been published:
    https://www.nature.com/articles/s41586-026-10614-4
    Apparently not summarized at Eurekalert, so readers will use that abstract, or email authors for the pdf. As shall I.
    Overall we are talking about < 1 meter of SLR through year 2100, unless something exciting happens. Some ports and ocean-facing cities may be directly troubled by that. Effects on salinization of coastal groundwater sources may be larger. Effects on storm surges with this (small) increase may be larger. It is all part of multi-factor challenge to Human Enterprise from burning more fossils and heating the place up; a challenge that will persist as long as old fossil-burning money prevails over new come from renewable-energy money in influencing governments’ policies.
    That’s simply how century 21 will go. One might hope for more rationality or less distractions to come from Greta Thunberg etc. But it’s old money vs. new opportunities.
    Good night and good luck.
  3. bwilson4web
    16,519
    I appreciate the good work going into getting finer details by:
    Felicity S. McCormack
    • Securing Antarctica’s Environmental Future, School of Earth, Atmosphere and Environment, Monash University, Clayton, Kulin Nations, Victoria, Australia
    Especially because she and likely her coauthors are beyond the grasp of our current climate deniers. The Earth is a large place and our home-grown deniers are such a small fraction, facts and data still rule other, off shore investigators.
    In the spirit of "Get off my yard," I've known since the Venus missions what the Earth climate outcome will be. There is a chance other disasters (aka., large body impacting Earth) can lead to massive die-offs. But I would bet (aka., invest in) man-made global warming leading to large populations becoming vulnerable.
    You can always count on Americans to do the right thing—after they have exhausted all other possibilities"—is most famously (but erroneously) attributed to Winston Churchill.​
    I lik this version too:
    Abba Eban is widely credited with a famous variation of this observation, famously stating, "Men and nations behave wisely once they have exhausted all other alternatives."
  4. tochatihu
    9,960
    3,845
    2001 Prius
    "I've known since the Venus missions what the Earth climate outcome will be."
    Not likely I say. Earth has been through very hot times in the past but kept its oceans. There is not enough fossil carbon to burn to make troposphere sufficiently infrared-dark to ruin the place in that way. Meanwhile, plants will take down some of the added CO2 and mostly, silicate minerals will trap more of it.
    Earth has become a place where it would be very hard to change temperature more than 10 oC in either direction in thousands years time frame. Within that range (particularly top half of that range), we shall have to make Human Enterprise work. Or else as they say.
    Don't work over much about deniers. When fossil money dries up they will go quiet or deny ever denying. Have you forgotten those who have already left us?
  5. tochatihu
    9,960
    3,845
    2001 Prius
    Instead we shall continue to eliminate species and replace them with farmed ones Yay human enterprise!
    A sad thing seen recently is major investments in energy production in Africa (renewable or otherwise) being crimped by low credit ratings of nations there involved. We are 'enterprising' kinda slowly.
    But the rich folks yachts and multi homes are joys to behold. Gini index and letting the Genie out of the bottle. Puns are confusing.
  6. tochatihu
    9,960
    3,845
    2001 Prius
    I learn that Dr. Felicity (mentioned above) is out of office on travel until sometime in July. So email later.
    On a yacht somewhere? I wouldn't know.
  7. bwilson4web
    16,519
    Perhaps I was imprecise, I knew that CO{2} cooked Venus which apparently has not developed the CO{2} purge and fixing mechanism of earth. Between 1960s and today, we've grown more clever about the expected quantities and research continues.
    I am reminded that predictions of CO{2} effects go back to the late 1800s:
    In 1896, Arrhenius published a landmark paper calculating how variations in carbon dioxide (\(CO_{2}\)) in the atmosphere could alter the Earth's surface temperature. [1, 2]
    • Calculations: Using calculations done by hand, he theorized that a doubling of atmospheric \(CO_{2}\) would significantly raise global temperatures, particularly in colder regions like northern Europe. [1, 2]
    • Fossil Fuels: He was also among the first to suggest that the large-scale burning of fossil fuels by humans could increase \(CO_{2}\) levels and drive global warming. [1, 2]
    As for long term trends: (1) fossil fuels become more expensive; (2) solar and wind become cheaper, and; (3) our species continues to seek the most efficient way.
  8. bisco
    52,805
    we should be living on mars by then, problem solved
  9. bwilson4web
    16,519
    Once tested on the moon.
  10. bisco
    52,805
    with the new funding, should move quickly
  11. ETC(SS)
    7,516
    Probably north of 3000m/s after the TLI burn......
    bwilson4web likes this.
  12. tochatihu
    9,960
    3,845
    2001 Prius
