Seal packings
Discussion in 'Gen 3 Prius Technical Discussion' started by Mellyman666, Nov 8, 2023.
  1. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    Hi !
    Head gasket job in process here. i attached back the cylinder head with the head bolts….I used permeate optimum red because that’s what the guy at the car parts suggested and it does high temps. But now in googling im finding that maybe it should have been ultra black.
    Opinions: worth taking out everything and restarting from scratch just to change seal packing? Or just continue and don’t use this seal packing anywhere else (timing chain cover and camshaft housing)? Keeping fingers crossed that it’s not that big a deal
  2. Tombukt2
    Tombukt2 Senior Member
    13,799
    2,501
    Durham NC
    Usually you use import gray on imports sports and imports but all of that crap is about very similar I wouldn't worry myself too much about it because of the color You're not all of a sudden going to have leaks you didn't have before It's letting the stuff skin and assembling properly is what makes or break an FIPG job.
  3. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
  4. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    FIPG seal is really good and we cannot find anything aftermarket as good as original FIPG Toyota. But we must make sure that the surface is completely clean and dry. Use isopropanol or brake cleaner before applying any seals.
