seat belt "b-off" but still beeping
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ystasino, May 5, 2007.
  1. ystasino
    ystasino Active Member
    792
    48
    Tucson, Arizona
    I have successfully disabled the reverse beep and have successfully set the seat-belt beep to b-off.
    When I power the car it is still beeping. If I insert the driver's seatbelt immediately after the first beep, the noise stops.
    Anyone have any ideas?
    Thanks
  2. hschuck
    hschuck Member
    385
    17
    bay city, ca
    Turning the seatbelt beeper off DOES NOT disable the beeper on startup; this beeper times-out in a few seconds. Turning the seatbelt beeper off DOES turn of the beeping that would be present if you were moving with the seat belt unfastened.
  3. ystasino
    792
    48
    Tucson, Arizona
    <div class='quotetop'>QUOTE(hschuck @ May 5 2007, 02:59 PM) [snapback]436098[/snapback]</div>
    Argh IU was afraid of something like that. It's not something I practice so this change is useless to me <_<
  4. AnOldHouse
    AnOldHouse Member
    677
    Middlesex County, Connecticut
    <div class='quotetop'>QUOTE(ystasino @ May 5 2007, 12:27 PM) [snapback]436067[/snapback]</div>
    Put your seat belt on before powering on your car. You do use your seat belt, don't you?
  5. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    Get a seat belt extension from your dealer. They are free and the beep won't go off as long as the extension is in place.
  6. ebederman
    ebederman New Member
    How did you disable the reverse beeping? I find it annoying. Might be good if the sound was outside, as a way to warn people. But I know when I'm in reverse. How do you disable this? Thanks
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Eric B @ May 6 2007, 05:46 AM) [snapback]436305[/snapback]</div>
    Here's one link.
    http://www.evnut.com/prius_beeper_disable.htm
    Dave M.
  8. ystasino
    792
    48
    Tucson, Arizona
    Make sure to NOT take your foot off the brake pedal during this sequence (not the emergency brake).
Loading...
