Seat belt chime…
Discussion in 'Gen 5 Prius Main Forum' started by George Jetson, Jan 31, 2024.
  1. George Jetson
    George Jetson Junior Member
    Moneta, VA USA
    2024 Prius
    Made the mistake of driving from my mailbox into the garage without my seatbelt buckled. The chime started out friendly enough but by the time I parked in the garage it sounded like a Vegas slot machine had just hit the jackpot. That’s gotta go…
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Something similar has been standard in all Prius since the start. Pretty easy to ignore on a short drive from mailbox to garage. And on a longer drive it'd be real easy to just put your seatbelt on so you're less likely to die if something unexpected happens.
    Alternatively, you can buy a mini-VCI dongle for $40, which comes with Toyota Techstream that you install on an old windows laptop to possibly change those settings. But that's assuming you already went through all the settings in the vehicle itself, which is the first thing you should check. And I'd also suggest reading the owner's manual but apparently no one's allowed to do that, so I won't bother.
    #2 PriusCamper, Jan 31, 2024
    George Jetson likes this.
  3. Preebee
    Preebee Senior Member
    900
    783
    Midwest
    2026 Prius Plug-in
    SE
    Easy fix. Just tell the dealership to turn it off next visit as they did mine. There is no menu setting.
  4. Chi_weezy
    Chi_weezy Junior Member
    35
    Sacramento
    2024 Prius Prime
    No way. Thank you I’m gonna do this. Never heard such a wicked chime. Also my battery is dead in my brand new car so have to go anyways.
  5. B2P
    B2P New Member
    Atlanta, GA
    2023 Prius
    Quick and easy fix: Unplug the seatbelt sensor from under the seat.
