Seat belt codes
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Apr 3, 2026.
  1. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    Anyone know if there's a pin to jump in the OBDII connector that will make lights flash on the dash to reveal seat belt codes? The airbag light is on, but I'm not getting anything with TorquePro. This is the car with the driver's seat belt that doesn't retract. This car also was in a front end collision that required a lots of parts to be replaced and left the airbag light on. IIRC, the seat belt was working after I repaired all the body wreck. It quit when I disconnected it to remove the floor carpeting.
    But, the airbag light has always been on since I got it, so I probably need to eliminate that too in case it's connected to the belt issue. Seems like a function that might have a OBDII pin to jump, like there is for wheel sensors, ac codes, et al.
  2. ChapmanF
    19,039
    ronlewis likes this.
  3. ronlewis
    1,061
    206
    texas
    2001 Prius
    Perfect, thank you, sir. That post describes jumping pins 4 and 13 almost like they are universal, i.e. display all the codes for all the ECUs. I'm thinking the ones for the brakes and AC might have dedicated pins as well. I'll check it out tomorrow.
  4. ChapmanF
    19,039
    If they did, we would have put that information on the blink-codes page.
