Seat Heater Too Hot
Discussion in 'Gen 3 Prius Main Forum' started by Dennis_MA, Feb 4, 2017.
  1. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    2012 Prius 4. The driver's seat gets way too hot. This has been happening since new. I have two other cars with seat heaters and none of them get this hot. I thought this was just me, but recently my wife confirmed the same thing (she rarely drives this car). The passenger seat works fine; my wife can leave that heater on the whole time. I have had it to the dealer and they say they can find nothing wrong. They tested both seats with a thermometer and they were within specs. If I turn it on first thing in the morning, within 2-4 minutes the heat is unbearable. The only solution from the dealer is to replace the seat at $1K. I have searched this site and the internet and can't seem to find any similar cases. Is anyone else had this problem?
  2. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Instead of having high and low settings, the Gen 3 Prius seat heaters cycle. They do get hot but then cool down some and then get hot again. Is it possible that your drivers seat is not cycling properly? My wife, who is sensitive to such things, commented on how hot her seat got but then decided that she likes the cycling. Our other vehicle has high and low settings with the high setting too high for ongoing use.
  3. Dennis_MA
    185
    109
    Amherst, MA
    I think it does cycle eventually. My problem is that I have a short commute to work so I turn it off and then back on after a few minutes. When I had it at the dealer, the seat heater was on for over an hour and it seemed fine for the trip home which was about 45 minutes to an hour. One of our other cars have high, medium and low. The heaters cycle down from high to low and they work fine on high. The other car like the Prius just has on and off that one works fine as well. In fact it is a little wimpy.
    #3 Dennis_MA, Feb 4, 2017
  4. Neohybrid
    Neohybrid Not-so-junior member
    165
    34
    Central Virginia
    We had the same problem with our 2012. I took it back to the dealer where we purchased and they ran the "temperature tests" only to tell me they couldn't find anything wrong. I then took it to the local dealer (where we purchased our 2008) and they did the "butt test" - the service guy actually sat in the seat - no fancy instruments needed. He removed the seat cover and found that the seat heater had bunched up in one location - likely when the cover was put on the seat. They replaced the heater element (believe it was the seat bottom, but reused the "pleather" cover). No problems for 4 years now!
    Bluegrassman and CNYhybrid like this.
  5. Dennis_MA
    185
    109
    Amherst, MA
    Thanks for the info. I suspected something like that. I will follow up with the dealer next week.
  6. qdllc
    qdllc Senior Member
    1,377
    400
    And, if worse comes to worse, it may be possible to do a in-line "resistor" to clamp down on the voltage going to the heating element, making it get "less hot" when running.
  7. ChapmanF
    19,020
    I'm pretty sure the cycling limit-switch is built in for safety requirements. The Plug-in Prius does offer high and low settings, and the wiring diagram shows limit switches for both settings....
    If you know anybody with a thermal imager (things like the FLIR ONE are crazy cheap now, at least compared to anything from a few years ago), it would be really easy to see whether the heat traces are bunched up in some way ... just turn on the heat and point the imager at the seat. You see the heat trace pattern very clearly. The normal pattern is a little denser in the areas where you'd expect.
    I respect the trade-off the engineers had to make on the heat power. In a good Indiana cold snap, the power is barely enough to notice, I can get all the way home without the seat feeling warm ... and then in merely chilly weather, it's overpowered and it does cycle too-hot...off...too-hot...off, which to me is annoying, I'd rather be able to turn it down to a lower output where it would never hit the limit temperature, and just stay steadily on.
    Probably the nicest solution would be to wire in adjustable heated-clothing temperature controllers (after measuring the power draw of the Prius heat pads and confirming the controllers can handle it). The controllers use rapid pulsing to vary the output, rapid enough that it doesn't feel like cycling on and off, and they do it without getting hot themselves (no current flow during the off pulses, no resistance to speak of during the on pulses).
    I wouldn't recommend just trying to put a resistor in series, because that will get significantly hot, calling for some careful thinking on the resistor size, ventilation, and mounting to protect materials nearby.
    -Chap
    SFO likes this.
  8. Barefoot
    Barefoot Junior Member
    43
    Lusby MD
    Our 2010 has 2 settings: off and too hot.
    Our '06 Sienna has a thumbwheel with about 6 clicks to adjust the heat. A much better arrangement.
  9. ChapmanF
    19,020
    Sooner or later, somebody's gonna try those heat controllers....
    -Chap
  10. royrose
    1,389
    953
    Foot of Pikes Peak
    Samprocat likes this.
  11. ChapmanF
    19,020
    I'd almost hope at the dealer someone would have a thermal imager these days, to be able to take a look in seconds without pulling the cover.
    As someone who has dealt with the hog rings on car seat upholstery before (and I was not being paid dealer tech wages to do it!) ... the labor saved cussing at just one or two seats worth of hog rings ought to pay for one of the newer cheap imagers.
    -Chap
  12. Steph R
    Steph R New Member
    Dedham MA
    2017 Prius v wagon
    YES!! Mine is painfully hot, both driver and passenger side. I don't know if it cycles because I can't tolerate the heat for more than 2 or 3 minutes. I'm bringing mine in for service soon and will ask if it can be adjusted.
  13. bisco
    52,853
    mine has hi and low. they're both too hot. i just toggle it on/off as needed.
    Johnny Cakes likes this.
  14. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    That's what I do. I press the start button. Turn on the driver's heated seat. Then start my commute. After about two or three minutes, at a traffic light, turn off the seat. It's plenty toasty, by then, the car's heater starts to kick in. May not be ideal, but the heated seat is still appreciated.:D
    KennyGS likes this.
  15. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I do the same. My wife however likes it on continuously, and I'm convinced will eventually spontaneously combust.
    Bay Stater likes this.
  16. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    My seat heater also had only on and off. After a few minutes it gets uncomfortable so I switch it off (the car heats up anyway) so I never tried if it would cycle at a certain temperature.
    It is not a luxury heater with different heat settings. It is on and off, so on must generate enough heat even when it is -20.
