Seat Height -- Obvious flaw in otherwise great car
Discussion in 'Gen 2 Prius Main Forum' started by nyprius, Jan 22, 2008.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    I wonder if an auto reupholstery shop could do. Maybe they could modify the foam.
    For Volvo's, they sell foam for the driver seat that lowers it about two inches. That seems like an ingenous solution.
  2. drees
    drees Senior Member
    1,782
    247
    FWIW, I sent them an email the other day with my complaints about the seat.
  3. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    Sure. Some people on PC have installed Recaro seats. They're very nice. But they're also very expensive, they don't match the interior as well as the OEM seats, and you lose the side air bags.
  4. nyprius
    nyprius Member
    385
    24
    That's a good idea. I also think it's possible to permanently lower the seat by an inch more by drilling new holes in some of the support brackets in the seat structure. I used to do things like that when I was a teenager 30 years ago. Now I don't have the time or inclination to do that kind of work. I'd much rather pay someone to do it.
    However, if I can't find someone to do it, frustration may drive me to pull the seat out and see what I can do. I've fixed everything else I didn't like on the car. I had the seats moved back three inches so I have lots of leg room up front. I had mud flaps, ding bars and a front and rear polybra installed.
    I put on way better tires than the junky OEM Integrities. I shut off the annoying reverse and seat belt beepers. I disconnected the crappy middle front speaker. I adjusted the HID headlights so they shine down the road where they're supposed to.
    I almost have the Prius to perfect car status. Seat height is the only thing standing in the way. Since I like to have things perfect, I'm probably not going to let this one slide. One way or the other, my driver's seat will be lower.
  5. westex39
    westex39 New Member
    60
    How did you move the seats back three inches? I have an idea how to do this, please give me your solution.
    Thanks,
    Wastex
  6. hill
    8,757
    dead link
  7. nyprius
    nyprius Member
    385
    24
    Hi Wastex, I took my car to New England Wheels in Billerica, MA. They move seats back for Boston Celtics players. They removed the front seats, drilled out the 8 pedestals on the four seat rails, welded about 5 inches of strong steel to the front of the seat rails, welded the pedestals back on 3 inches forward from their original position, painted the assemblies black, then re-installed the seats. This caused the seat sliding range to be shifted back three inches.
    My 5'3" girlfriend has no problem driving the car when the seat is all the way forward. Apparently the front seat of the Prius is designed for people in the height range of about 4'6" to 5'8". That might make sense for other countries, but not the US.
    I usually drive the car with the seat 2 inches farther back then the farthest back seat position in a non-modified Prius. It's way more comfortable!
    The very first time I sat in a Prius, I kept trying to push the seat back more. Just like the mistake of not providing seat height adjustment, I think it was a mistake to set the range of front seat travel so far forward. Perhaps Toyota wanted to claim lots of rear legroom for the Prius. But in my car, as I suspect in many others, people are rarely in the back seat. Preference should be given to front seat legroom. I can always slide the seat forward to give tall people in the back more legroom.
    However, even with my seats slid back three inches more than a regular Prius, there is still enough leg room for a tall person to sit in the back.
    Bottom line: I think US Toyota made a mistake on seat travel range as well as lack of seat height adjustment.
  8. nyprius
    nyprius Member
    385
    24
    Excellent! If many of us do this, Toyota may provide a height adjustment retrofit that enables Prius owners to be comfortable and safe in their cars.
  9. drees
    drees Senior Member
    1,782
    247
    I'm already a bit further away from the steering wheel than I'd like (I can't quite rest my wrist on the top of the wheel without stretching or cramping my legs). Though I would prefer a lower seating position, I worry that without a telescoping steering wheel I'll have to stretch a bit more to reach the steering wheel.
    Driving "gangsta style with my lean on" to reach the steering wheel isn't exactly the best position to sit in to easily maintain full control of the car.
    Just have a look at how close your typical race driver sits to the steering wheel.
  10. nyprius
    nyprius Member
    385
    24
    I think this has a lot to do with seating preference. For example, I always have the seat back leaned all the way forward because I like to sit with my back as straight up as possible. This means my arms aren't that far away from the wheel, even when I have the seat slid 2 inches further back than is possible in a non-modified Prius.
    However, if someone likes to recline the seat back when they drive, their arms will be pulled away from the steering wheel. In that case, a telescoping wheel might be needed for all who aren't built like gorillas.
  11. westex39
    westex39 New Member
    60
    NYPrius,
    Thank you very much for the detailed explanation. My plan differs somewhat from theirs. Should achieve the same result. I am worried about being set back to far from the steering wheel. I like the seat in a reclined position. I plan to build a test piece from plywood to position the seat back 3" and try it. Hope it works.
    Thanks again
    westex39
  12. dogfriend
    7,512
    1,189
    Carmichael, CA
    Unfortunately, I think there are several reasons (both technical and financial) why they probably won't do this.
    To add height adjustment to the current (non adjustable) Prius seat, they would essentially have to replace the entire upper seat frame. That's because the seat support bracket is welded to the seat frame. I had to cut this bracket to lower the rear of my seat. For Toyota, it would be easier (and safer) to replace the entire seat.
    I think the best you could hope for is that they would offer to sell the adjustable seat found in the European and Japanese market. But if you look at the prices that Toyota charges for new replacement seats, you could buy a Recaro for less money.
    BTW, I discovered that Recaro now sells seats with side airbags, so that could possibly be a solution, although an expensive one.
    It would be possible for an aftermarket company to offer a "kit" to modify the Prius seat, but I would not hold my breath for this - the liability involved is tremendous - and the volumes would be low, so it isn't very likely that someone would go to the trouble to design and market a kit to modify the Toyota seat.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Awesome! I thought it was just me. I love the car but I'm always kinda hunched over the wheel. Was not sure how to fix it. Could you please elaborate on your fix. 14 washers is about 3/4 of an inch? Are you propping up just the front of the seat? Thanks alot!
  14. patsparks
    10,664
    567
    Adelaide South Australia
    No you don't lose the side airbag, Recaro are made (only for left hand drive vehicles) with a side airbag.
    Work out the cost of a Recaro over the life of the seat taking into account the added resale value of a car with a like new, no wear drivers seat, reduces fatgue, and portability to the next car and the cost per mile is very low.
    Of course we could just say Toyota should have fitted the Prius with seats as good as Recaro at no additional cost and cry a lot but what will that achieve?
    I put my spine above the interior asthetics of my car, where do you rate your spine?
    I should add, I am happy with the standard height adjustable seat in my Prius :D
  15. nyprius
    nyprius Member
    385
    24
    Hi Westex39, if you like to recline the seat back, then moving the seat position back via the mod I did might put you too far from the steering wheel. Re doing the plywood test, I had the car modified twice. The first time, I took it to a handicap retrofitter who had never moved Prius seats back. They cut 4 pieces of about 3/8" thick strong steel about 5 by 2 inches, then drilled holes 3" apart in them. Then they took out the seats, bolted the metal onto the floor where the seat was fastened, then bolted the seat to the new metal. This moved the seat back, but it also raised it and tilted it back too much. So I had them return it to the original set up.
    Then I found New England Wheels. They did the mod I described above. It works perfectly. By extending the seat rails, the seat is not raised. In fact, since the rails angle slightly backwards, moving the seat further back lowers it a little. But I want it lowered more.
    The lowering mod is tougher, because as someone said, you have to work within the seat structure, rather than on the seat rails.
  16. nyprius
    nyprius Member
    385
    24
    Thanks Dogfriend, I think you're right. I called a UK Toyota dealer to get a price on a left front height adjustable seat. He estimated the cost at £1700. I think that's more than three times the Recaro cost. But I only want to lower the driver's seat an inch. Putting in two Recaro seats for that seems excessive.
    You mentioned you cut the bracket to lower the rear of the seat. How much did you lower it? Would it have been possible to lower the front by an equal amount to retain the same seat angle?
    Lowering only the rear of the seat would cause the seat back to lean back more. If anything, I'd like it to lean more forward than it's maximum forward position. Personally, I like to sit up straight rather than lean back. So lowering the rear of the seat only isn't a viable option for me, though I can see how it might be for others.
  17. dogfriend
    7,512
    1,189
    Carmichael, CA
    I posted photos in another thread:
    http://priuschat.com/forums/prius-modifications/21751-seat-height-adjustment-2.html#post549147
    I lowered the seat approx. .890 inch (new hole was drilled .890 below original rivet hole). It did tilt the seat bottom but I wanted to tilt it anyway because the original angle felt too flat. It is true that the seat back now angles back also, but this can be remedied with the recline adjustment - even with the additional tilt, I can tilt the seat back upright - like you, I prefer to sit upright, now I can do that without my hair touching the headliner.
    Yes, I believe that you could lower the front and rear, but may require fabricating a new bracket for the front. Also, it would be possible to lower the rear more than I did, but that distance was convenient because the flat area on the bracket matched the original rivet hole location. Lowering it further would require fabricating a bracket and rerouting the wires for the seat belt warning buzzer.
    I am planning to look at making the seat adjustable - this would require new brackets for the front and rear, plus a mechanism to raise and lower the seat. I have an idea how to do this, but have not yet drawn the geometry to see how the brackets will articulate. I have a Corolla seat to use as a pattern - that will help me to determine pivot points and lengths of the brackets. The articulation of the Corolla seat is interesting - at first it lowers both the front and rear of the seat but the further you lower it, it lowers the front less than the rear, effectively tilting the seat bottom as it lowers. Also, the whole seat moves rearward as it lowers which increases legroom as well.
    However, I am pretty happy with my seat now compared to before, so I am less motivated at this point to change it.
  18. seattleprius99
    seattleprius99 New Member
    I would imagine that if you were in a serious accident with one of these modified seats, and your seat failed for one reason or another, and if the insurance company found out you had modified the seat in any way, you may risk not getting coverage for your injuries. So modifying the seat may be very risky.
    To all the people who are over 6 feet tall and feel the Prius is too small for them, I would say look at the Camry Hybrid, or the Highlander Hybrid. The Prius was designed as a Japanese domestic market car, and a world car too, not just a car for big Americans. Personally as someone who is 5'6" tall, the Prius is the perfect size for me. And I am glad they designed it this size, as I would never be interested in driving a Highlander Hybrid or even a Camry Hybrid as I do not want a big car.
    But people who are big, and I believe people over 6 feet tall are big people, you need to buy a bigger car if you're not satisfied with the one you have.
  19. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    i don't really have a problem with the prius seat, but after driving our 1990 lexus i have to say that it's vastly more comfortable.
    going back to the prius feels a little weird.
  20. darelldd
    6,059
    389
    Northern CA
    You're just mean.
