Seat lumbar support
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tkrishnan, Oct 9, 2012.
  1. tkrishnan
    tkrishnan New Member
    I feel that the lack of lumbar support in the Base PIP is a real negative, esp, for folks with long commutes like me. In the last 3-4 weeks I have owned it, I am starting to develop a slight back ache.
    I am planning to buy after market lumbar support. Are there any specific makes/models you would recommend?
    Also, are there other things you can do to make the driver seat more comfy?
  2. hill
    9,041
    If you think the lumbar support suck on the PiP - you ought to try long drives in the Gen II - notoriously hideous
    That said, lumbar support is a totally personal thing. What works for one, will kill someone else. Your best bet is to simpy give the tons of different goodies a try. I use a little blow up cushion - while my wife has a different style mesh support. Good luck!
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yep, you are just going to have to experiment.
    The good news, or the bad news depending on how you want to look at it, is that there indeed are a lot of products and options on the market.
    I've seen relatively decent mesh back lumbar supports in The Dollar Tree...to the seat cushions that vibrate and massage...
    But what addition may or may not work for you? Experimentation is all you can really do.
  4. terpsmandan
    terpsmandan Member
    144
    I got mine two weeks ago and was driving a Jeep Wrangler before and my back was hurting a bit at first. I just turned the seat heaters on and now my back is used to the position of the seat and no problems.
  5. tkrishnan
    I guess this means you cant buy it off the internet since you need to try a bunch of them first. What stores sell these? Auto parts stores? Would target or a place like bed, bath & beyond have it?
  6. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I have a McKenzie Lumbar Roll for lumbar support. I have multiple herniated discs, and rely on this roll whenever I am sitting anywhere (it really helps). McKenzie literally wrote the book (highly recommend it) on treating bad backs, and my physical therapist recommended this product as well. Comes with a strap, so I guess you could tie it around the seat if you want to keep it in the car.
  7. Adam Leibovitch
    498
    102
  8. tkrishnan
    Thanks Adam. I bought what you suggested and so far it seems to be working great.
