Seats too relaxed/reclined?!
Discussion in 'Gen 3 Prius Main Forum' started by rmi, Feb 3, 2012.
  1. Den49
    Den49 Member
    498
    272
    Maryland
    Below are instructions for removing the driver’s seat and inserting foam padding between the springs and existing seatback pad. I am very confident that if you have average DIY skills you can do this.
    Prius Driver’s Seat Removal:
    1. Disconnect the negative terminal from the 12V battery in the rear hatch area. (This is optional. I have done this many times without disconnecting the battery.)
    2. Press in the headrest adjustment button and pull up to remove the headrest. Removing the headrest will make it easier to get the seat out of the car.
    3. Lift the bar under the front of the seat and move the seat to its foremost position.
    4. Remove the two trim caps that cover the seat-to-floor mounting bolts on the rear of the left and right seat tracks.
    5. Remove the two rear seat-to-floor mounting bolts with a ratchet wrench and 14mm socket.
    6. Lift the bar under the front of the seat and move the seat to its rearmost position.
    7. Remove the two front seat-to-floor mounting bolts.
    8. Lift the bar under the front of the seat and move the seat to the center position.
    9. Operate the reclining adjuster release handle and move the seatback to the full upright position.
    10. Tilt the seat back to gain access to the underside of the seat.
    11. Disconnect the electrical connectors under the seat.
    12. Lift the seat, rotate it to the left and remove it from the car through the driver’s door opening.
    Open the Seatback Cover:
    1. Place the seat upside down on top of a piece of carpeting or cardboard to protect the fabric or leather.
    2. Unhook the rear seat cover flap on the underside of the seat.
    3. Remove the three hog rings at the base of the seatback. Two needle-nose pliers work good for opening the hog rings.
    4. Unzip the two zippers at the base of the seatback.
    5. Pull up the unzipped seatback cover.
    At this point you will have access to insert foam padding between the back seat springs and the existing seat pad. I inserted a 1” high density foam pad above the lumbar support. I think it was about 8” X 12-14”. One inch of foam provides a good deal of support, more that what you might think; so install it, turn the seat over and give it a try. It may be all you need; it was for me. If you need more foam, I think you can add another ½” to 1”. When you get to this point it is just a simple matter of inserting foam and trying the seat until you get it to where you are comfortable. Reverse these instructions to close up the seatback cover and reinstall the seat.
    Robert Holt and 67tony like this.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I believe the Toyota instructions for seat removal would include disconnecting the 12V auxiliary battery, then waiting at least 90 seconds before disconnecting any connectors, the airbag especially, under the seat.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    The Toyota manual does call for disconnecting the negative battery terminal as the first step. I have removed the seats on my Prius and numerous other cars without disconnecting the 12V battery. It is really not necessary. The air bags cannot be set off by moving or working on the seat and are completely disabled as soon as the electricity is disconnected. However, it is always a good idea to disconnect the 12V battery or take any other safety measure that you deem necessary. I will amend my prior post to include this. Thanks.
  4. rmi
    rmi Junior Member
    38
    Athens, GA
    Thanks for the help! Did you just use a rectangular 8x12 piece of foam or did you shape/contour the foam to look/feel better? Got any pictures of the final product? Did you mod the passenger seat as well? While I am the primary driver of this vehicle, its our "family car" too, meaning that my wife will drive it a good bit. Is your modification something that people comment on when they sit in the car or do most not even notice?
    Thanks again- Ryan
    Update: After another drive to work this morning, I realize that the forwardmost position is too far forward. After the initial (and emotional) shock of realizing that my first (and only) new car doesn't feel all that great.....I am resolved to make this thing fit me. After Den49's suggestion, I realized that it may just be the shape of the seat that is the problem. After 6 years of people complaining about the lack of lumbar support in the Gen 2, Toyota seemed to respond and built in more support. Unfortunately for me, I would probably prefer a "flatter" seat back profile (I have to sit in my coworkers' Gen 2 Priuses to confirm) where my shoulders get more support from the seat. I think my problem is that my lower back is supported, but, to feel like my upper back is supported, I need to arch backwards until my shoulders hit the seat. Bulking up the upper seatback MAY be just what I need. Just a thin hand towel folded behind my shoulder blades felt quite nice.....and I was two clicks reclined!
    Thanks all for the continuing suggestions and support. Hopefully, I will have something of value to contribute one day. If nothing else, I will take pics of my modifications. The Ninja 250 forum has an INCREDIBLE FAQ/How-to section compiled over the years by users. Prius Chat have something like this?
    Ryan
  5. Den49
    Den49 Member
    498
    272
    Maryland
    Just a flat rectangular piece of foam.
    My wife has the car today. I'll see if I can click a photo and post it tonight; however, there is no significant change to the appearance of the seat after the foam is added. If anything, it looks better because the leather is bolstered up and not wrinkled.
    Yes, and it improved its comfort also. I also added foam to the seat bottoms because they needed it after over two years and 33,000 miles of driving.
    My wife also liked the change to the seats, which is remarkable because she, as a 5'6", 125 lb. woman, has a different body/back shape than I and isn't always comfortable in chairs that I find comfortable and vice versa. I suggest you have your wife test the seat(s) along with you to insure the changes you make are comfortable for both of you.
    You have correctly diagnosed the problem. The sooner you correct the contour of your seatback, the sooner you will get relief. Also, the longer you contort your back in a way that causes you pain, the more you risk injury.
    If you follow my instructions, you will find it to not be as difficult as you may be thinking. Things become obvious as you go through the steps. You will become expert at it by the time you finish.
    [/QUOTE]
  6. Den49
    Den49 Member
    498
    272
    Maryland
    Attached are pictures of the driver and passenger seats after 1" foam was installed in the bottom and back of both seats. The foam was installed about six months ago at about 33,000 miles. The car now has 43,000 miles and the seats are still very comfortable, more so than the 2007 Camry XLE that I recently traded-in.
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    The steering wheel definitely adds to the problem -- Both in design of the wheel and the fact that the movement is limited based on its orientation.
  8. rmi
    rmi Junior Member
    38
    Athens, GA
    They look great! Thanks for the pictures and the advice in the post above.
    I am already looking up upholstery shops in town to buy some foam. Hopefully, I'll be able to get everything done this weekend. I am worried about the seat cover going back on, but trust that there is enough fabric to accommodate the extra volume.
    Ryan
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i used to feel awkward in my seat... i pushed it up strait like you have yours... but then it's too much pressure on my lower back.. so i added in one of those cheap 2 dollar black mesh back supports. this pushes my butt forward a tad bit. gives me better support (side support too!)... in the end it feels more comfortable as a full package. i get the support i want... the seat up like i want it.. but doesn't make me feel like i'm being folded into a piece of paper.
    btw.. side note.. i hate the seat bottoms of my genII... as with most cars.. too bouncy..
  10. Den49
    Den49 Member
    498
    272
    Maryland
    The larger craft stores also sell foam.
    Don't worry about getting the seat cover back on; it will not be a problem.
    Tip: To disconnect the electrical connectors under the seat, use a small thin blade screw driver to push in the catch and then push off the free end (not attached to the seat) of the connector.
    Hope all goes well. Let us know and post some pictures when you have completed the job.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I've had my seats upholstery off. Your instructions look good. One thing I would add is to be sure to use high quality dense foam so it won't fail with use.
  12. rmi
    rmi Junior Member
    38
    Athens, GA
    Update 2/13/12:
    Well, I added a 10x12 piece of 1 inch thick, high density foam according to Den49's directions earlier in this thread.
    I don't want to jump to any conclusions because I have only driven like 40 miles with the modification, but......
    It seems amazing! Instead of the seat being concave were your shoulders hit the seat, the seat back looks nice and flat now. My shoulders have a good deal of support and the lumbar support is not jabbing into my back.
    I bought a big piece of 1 inch high density foam from an upholstery shop for $10 (I can probably do 13 mods with the amount of foam that I have left over). I took pictures of the whole process (wires under seat, what the seat looks like without the cover, replacing hog ties with zip ties, etc) that I will post later. I also made some notes of helpful hints for people wanting to do this mod (like you need a 10mm wrench to disconnnect the 12v.....an adjustable wrench is just too big).
    Anyway, thanks again for all the advice. I think I may have found my key to comfort in the Prius. I am going to drive this week and see if I like it and will post pictures of the process soon.
    Ryan
  13. Den49
    Den49 Member
    498
    272
    Maryland
    Glad to hear that the foam worked for you. It has worked for me in every car I used it. You may have to replace the foam in a couple years, but now that you know how, it will be a snap.
    Along with relieving your physical pain, isn't wonderful to also be relieved of the psychological stress of thinking you made a mistake purchasing the Prius.
  14. rmi
    rmi Junior Member
    38
    Athens, GA
    Glad to have the physical pain gone, and glad to be one step closer to loving the Prius. Some little details of this car are really weird, though. Who were these seats designed for? Whose backs are they shaped for?
    Why is the steering wheel not dead center in front of the driver (at least when fully telescoped)? What do I do when 65 is too hot and Lo is too low (using the heat on a cold morning)? Why does such an expensive car have only OK radio reception?.....
    Can't say that I have worked out all the quirks of the vehicle, but I am MUCH happier!
    Thanks again- Ryan
  15. clof
    clof Junior Member
    I agree - I find the Prius seat very uncomfortable as well. I drive a minimum of 150 miles per day and after the first week of owning the car I could hardly stand up straight - my back ached so badly. I also previously owned European cars and find their seating much superior. Even all the American cars I've owned were much better. I found that my problem was poor lumbar support. I purchased a VARILITE Portable Self-Inflating Back Lumbar Support Pillow which I place behind my back and it works great! I couldn't drive this car as much as I do without it. I will be installing an after-market permanent air adjustable lumbar support into the seat as soon as the weather gets warmer.
  16. xPETEx
    xPETEx Junior Member
    76
    Victoria, BC, Canada
    2013 Prius v wagon
    rmi did you ever post up those pictures? any long term updates on the comfort?
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I could definitely see this being a problem for some people. The whole thing works well enough for me.
    I have to keep my seatback reclined somewhat. If I put it forward, angle between seat cushion and seatback is too little and I'll feel like I'm sitting in a bucket (no pun intended).
    In my opinion, the 3rd gen liftback mechanical adjust seat cushion bottom has a lot of tilt to it (front edge of seat angled up quite a bit). I'm really tall and had to give about 3 pumps up on the height adjust handle to take a little tilt out.
    One problem is mechanical adjust driver's seat are in my opinion a 'crap shoot'. There's hardly any way to make them work for everyone.
    * It would really help a lot to have a good seat bottom tilt knob at the left front side of the seat cushion. That way you could increase or decrease the seat bottom tilt. Little bit more expensive seat, but really not much.
    Other than that, best to get a good power adjustable seat. btw, my 1988 SR5 Toyota 4WD pickup has seat bottom tilt knob. I've seen it in FJ cruiser too. Prius ought to have one.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    When you loosen the steering wheel adjustment lever and move the wheel through all its positions, it's comical how little the adjustment range is.
  19. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Sitting on an office chair for computer use is quite different than driving position. So you are quite wrong about 90 degree (nose over steering wheel). Having said that, I use a (cheap) lumbar support in my Prius and it really makes a difference when driving long distances on hot days.
  20. rmi
    rmi Junior Member
    38
    Athens, GA
    Never uploaded any photos, but the end result looked very similar to Den49's photos above. The upper back area is just "pushed out" a little more than the stock seat.
    I thought the modification was good, but was not perfect. Thinking that I hadn't given the stock seats enough time, I took the foam out. And that's where I am now.
    I still think the stock seats are REALLY uncomfortable. I have never driven in a car that was so uncomfortable, and I have driven in quite a few more since I got the Prius and started this thread.
    Long term solution? I have no idea. I am thinking about starting all over again and putting the foam back in.
    On the best days, I think the Prius seat is acceptable. On the worst days, I kick myself that I wasted a ton of money on a car that I can barely drive without pain. :(
