Seats
Discussion in 'Gen 5 Prius Main Forum' started by easyryderca, Apr 17, 2026.
  1. easyryderca
    easyryderca New Member
    British columbia canada
    2026 Prius Plug-in
    SE
    Hi folks new to the forum. Just bought a 2026 se hybrid. Finding the driver seat uncomfortable as I suffer with bad back pain. Wondering if others have had the same issue. Thanks
  2. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    Not sure if your SE gives you full power seat controls, I got a tip once from my chiropractor to raise up the front lip of the seat, which kind of lifts the default position of your knees and I guess relieves lower back pressure. This is not the height of the entire seat, but just the height of the very front part of the seat. My XLE also has lumbar support so when I'm having back issues, I also adjust that part of the seat.
  3. easyryderca
    2026 Prius Plug-in
    SE
    Thanks . Its appreciated.
  4. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    There's all kinds of products you can put on a car seat to make it more comfortable. As always with back issues get details on what your doctor, physical therapist and chiropractor think will work best for you.
  5. bisco
    52,861
    welcome!
    what vehicle are you coming from, and was it comfortable?
  6. easyryderca
    2026 Prius Plug-in
    SE
    Came from a Subaru Imprezza sport tech with lumbar support.Thanks
  7. easyryderca
    2026 Prius Plug-in
    SE
    Thanks.
    #7 easyryderca, Apr 17, 2026
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Seats for me are fine. It's the fact that they stain VERY VERY EASILY.
    Like water will cause a stain.
  9. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    I really like the pleather seat covers I installed.
  10. easyryderca
    2026 Prius Plug-in
    SE
    Thanks folks for the info.
  11. Hammersmith
    Hammersmith Senior Member
    2,493
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Three years in, no problems with seats. I've done 10-15hr trips in basically one sitting and finished with energy to keep going. (only stops for restrooms and gas+quick food) In my previous gen3, I was completely worn out after similar trips. I'm sure a big part of that has to do with the gen5 driving aids, but still...
    Original set of seat covers were perfect when I replaced them last fall. Current set came out of a wrecked car and are also perfect. (I swapped my black Limited softex seat covers with the softex covers from a Prime XSE so I could have the red accents to match my red paint.)
    I use a small extraction carpet cleaner with heat if I ever have to clean a serious stain. I also keep the P&S carpet cleaning system on hand, which also works on upholstery. You start with their Terminator enzyme cleaner to break down organic stains, follow up with their Carpet Bomber cleaner to break down everything else. Then I do an extraction with a little bit of clean water to get everything out of the carpet/upholstery. The final step is their Finisher, which uses peroxide to do a mild form of what an ozone machine does. It's about $35 for all three bottles(1 pint of each), but it goes a long, long way.
