second 12 volt battery - 2020 edition
Discussion in 'Gen 3 Prius Main Forum' started by geedub, Apr 27, 2020.
  1. ChapmanF
    19,025
    That strikes me as a practical approach and is probably the one I'd follow. The key is having the jump pack so that even if there is an issue, you'll be able to take it in stride and not be much inconvenienced by it, If your experience leads you to add more capacity, you can do that at any future time.
    You should note that the car's 12V sockets are off when the car is off, so if you think you ever will want to let the Dometic run with the car off, you will want to direct wire (and appropriately fuse).
    In that case, you will be counting on the Dometic's low-voltage cutout to leave you with adequate starting charge if you are longer returning to the car than you planned. The "VCM-06" module in my arrangement above has a similar function, with a fixed shutoff point of 11.8 volts, which always leaves plenty to start the car with no trouble.
    My original battery made it to ten years (disclosure: I only had this rig on it for the last four), so the occasional discharge to that point wouldn't seem to have sacrificed longevity much. If it were a regular occurrence that could be different.
    Naturally if you will be trusting food that you keep in there, you will want some way of knowing whether the Dometic shut off while you were away, and for how long it was off, and what temperature it reached. I'm not aware of how they handle that, It seems they make some mention of logging data to your phone, but I don't know if they include some kind of backup battery so it would continue to log temperature while shut off. If they're not doing that yet, I guess I've just given away another idea....
    geedub likes this.
  2. geedub
    geedub Member
    127
    82
    Flordia
    Cool. Do you have a 12v socket in the back? I refuse to learn about electronics at this time, at least until after I figure out early retirement Social Security while working.
    I'm surprised how often the car runs with only an Igloo thermoelectric cooler hooked up. It's every 20-30 minutes, with no climate control at all. We've had some nice cool nights in the 50's (12ºC) here lately so I've had the windows down. I've also learned that this cooler will freeze eggs under those conditions.
    If I install a 1000 watt inverter what would that do to the idea of only using the one 12 volt battery?
  3. ChapmanF
    19,025
    Well, my thermoelectric cooler draws something like 50 watts. That's why people prefer things like the Dometic, averaging 12 or 13 watts over time to keep your stuff chilled. You've got about 540 watthours total of energy in a (newish, fully charged) battery: 45 amphours times 12 volts (nominally). At twelve watts the Dometic could run for a decent time if it had to.
    Adding a 1000 watt inverter by itself won't change much. :) Plugging stuff into the inverter will. If you really plan to plug in a thousand watts worth of stuff, well, that's equivalent to running about eighty Dometic coolers, right? That won't hold up for as long.
    Minima Domum and geedub like this.
  4. geedub
    geedub Member
    127
    82
    Flordia
    Yeah, I just tried charging a cordless drill battery and it didn't like my 300W plug in inverter.
    So, inverter = 2nd battery?
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    A 12v fridge draws significantly more current than 1A. I was skeptical about the current so I consulted the manual, yes no one ever does that anymore. The fridge pulls 7.5 amperes at 12v so it’s easy enough to just buy an in-line fuse holder, 110 amp fuse, pair of power leads with quick disconnects and pair of battery lock terminals that allows you to use pair of cable for each. Won’t cost more than $50 to rig this up on your own. Not sure how you all went with solar and inverters.
  6. ChapmanF
    19,025
    When they specify 0.98 amphours per hour, they are talking about the average consumption of the fridge while it is keeping your food cool. That will be more than 0.98 amps when the compressor is running, and close to zero amps while it is cycled off. They specify the overall average (and under what conditions, 90 °F outside the box and 39 °F inside) so you can divide it into your battery capacity and know how long it can keep your food cool before the battery is drained.
    Yes, for choosing wire and fuse size, you need to know the actual amp draw when the compressor is running.
    geedub likes this.
  7. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Jerry, I've added a second 12V battery to my 2010 Prius. The link is in my signature below.
    geedub likes this.
  8. geedub
    geedub Member
    127
    82
    Flordia
    Thanks Terrell, I'll check it out.
  9. geedub
    geedub Member
    127
    82
    Flordia
    Are the interiors of the 2010's identical to the 2012's? It appears that even the smallest Dometic CFX3 won't fit behind my passenger seat due to the center console.
  10. geedub
    geedub Member
    127
    82
    Flordia
    I just took a look at the Dometic lithium 40 Ah portable battery. My first thought was, damn, I never thought I would consider spending $900 on a battery for recreational purposes. Then I realized that I was already considering spending several $100's on a second battery set up. The portable battery has some interesting advantages over the hardwired systems.
    You can take a fridge just about anywhere or leave it at camp if you trust your neighbors.
    Has anyone used one? LINK
    #30 geedub, May 6, 2020
    Minima Domum likes this.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I have no experience with the Dometic battery, but that's a lot of money for a 40Ah battery.
  12. geedub
    geedub Member
    127
    82
    Flordia
    That's what I thought until I looked for other similar batteries. I found one 100Ah LifePO4 on Amazon for $700 but who knows what the quality is? There are other 100Ah examples in $1200-1300 range. Some of these have battery management systems, but the Dometic has that plus an integrated charger for solar, 12v or 110. The others are like most batteries - a box with two posts but the Dometic is truly portable with no exposed connections.
    I agree that Dometic has priced this unit as if there's no competition, but so far I haven't found any competition for it. If this was 100Ah or even 80Ah, I would have already bought one...
    Here's a section on LifePO4 from wikipedia:
    Advantages and disadvantages
    The LiFePO
    4 battery uses a lithium-ion-derived chemistry and shares many advantages and disadvantages with other lithium-ion battery chemistries. However, there are significant differences.
    LFP chemistry offers a longer cycle life than other lithium-ion approaches.[14]
    Like nickel-based rechargeable batteries (and unlike other lithium ion batteries),[15] LiFePO
    4 batteries have a very constant discharge voltage. Voltage stays close to 3.2 V during discharge until the cell is exhausted. This allows the cell to deliver virtually full power until it is discharged, and it can greatly simplify or even eliminate the need for voltage regulation circuitry.
    Because of the nominal 3.2 V output, four cells can be placed in series for a nominal voltage of 12.8 V. This comes close to the nominal voltage of six-cell lead-acid batteries. Along with the good safety characteristics of LFP batteries, this makes LFP a good potential replacement for lead-acid batteries in applications such as automotive and solar applications, provided the charging systems are adapted not to damage the LFP cells through excessive charging voltages (beyond 3.6 volts DC per cell while under charge), temperature-based voltage compensation, equalisation attempts or continuous trickle charging. The LFP cells must be at least balanced initially before the pack is assembled and a protection system also needs to be implemented to ensure no cell can be discharged below a voltage of 2.5 V or severe damage will occur in most instances.
    The use of phosphates avoids cobalt's cost and environmental concerns, particularly concerns about cobalt entering the environment through improper disposal.[14]
    LiFePO
    4 has higher current or peak-power ratings than LiCoO
    2.[16]
    The energy density (energy/volume) of a new LFP battery is some 14% lower than that of a new LiCoO
    2 battery.[17] Also, many brands of LFPs, as well as cells within a given brand of LFP batteries, have a lower discharge rate than lead-acid or LiCoO
    2.[citation needed] Since discharge rate is a percentage of battery capacity a higher rate can be achieved by using a larger battery (more ampere hours) if low-current batteries must be used. Better yet, a high current LFP cell (which will have a higher discharge rate than a lead acid or LiCoO
    2 battery of the same capacity) can be used.
    LiFePO
    4 cells experience a slower rate of capacity loss (aka greater calendar-life) than lithium-ion battery chemistries such as LiCoO
    2 cobalt or LiMn
    2O
    4 manganese spinel lithium-ion polymer batteries (LiPo battery) or lithium-ion batteries.[18] After one year on the shelf, a LiFePO
    4 cell typically has approximately the same energy density as a LiCoO
    2 Li-ion cell, because of LFP's slower decline of energy density.[citation needed]
    Compared to other lithium chemistries, LFP experiences much slower degradation when stored in a fully charged state. This makes LFP a good choice for standby use.[citation needed]
    Safety
    One important advantage over other lithium-ion chemistries is thermal and chemical stability, which improves battery safety.[14] LiFePO
    4 is an intrinsically safer cathode material than LiCoO
    2 and manganese spinel, through omission of the cobalt, with its negative temperature coefficient of resistance that can encourage thermal runaway. The P–O bond in the (PO
    4)3−
    ion is stronger than the Co–O bond in the (CoO
    2)−
    ion, so that when abused (short-circuited, overheated, etc.), the oxygen atoms are released more slowly. This stabilization of the redox energies also promotes faster ion migration.[15]
    As lithium migrates out of the cathode in a LiCoO
    2 cell, the CoO
    2 undergoes non-linear expansion that affects the structural integrity of the cell. The fully lithiated and unlithiated states of LiFePO
    4 are structurally similar which means that LiFePO
    4 cells are more structurally stable than LiCoO
    2 cells.[citation needed]
    No lithium remains in the cathode of a fully charged LiFePO
    4 cell. (In a LiCoO
    2 cell, approximately 50% remains.) LiFePO
    4 is highly resilient during oxygen loss, which typically results in an exothermic reaction in other lithium cells.[8] As a result, LiFePO
    4 cells are harder to ignite in the event of mishandling (especially during charge). The LiFePO
    4 battery does not decompose at high temperatures.[14]
  13. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    geedub likes this.
  14. geedub
    geedub Member
    127
    82
    Flordia
    Interesting. I assume this is lithium ion. The LifePO4 batteries are supposed to be less likely to explode and much long lasting in general. Looks like this jump pack only charges via 110v. Something to think about at 25% the cost. Thanks!
  15. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Does anyone know what the charging profile is like on the factory DC-DC charger (that charges the standard 12v battery from the HV system when the car is "ready") is it just a 14.x volt constant power supply or does it ramp current/voltage up+down like a 'real' charger?
    Id like to get rid of the poxy little 12v battery completely and replace it with a much bigger lithium pack if the standard charging system will cope, I have solar on the roof and my solar controller is lithium capable but I can't find any info on the factory charger.
  16. ChapmanF
    19,025
    Use caution interpreting the advertised milliamphour figures for lithium jump packs. There seems to be a common, ahem, "convention" used when publishing those numbers.
    For example, here's the label on the back of my little one:
    As far as I can tell, you don't get shown the "29.6 Wh" number anywhere else: not online at their web site, not in the booklet that comes with it, just in that one place, on the label.
    Online, the advertising for this unit is "8000 mAh".
    This is where the alert reader does a little bit of mental arithmetic and says "hey, wait a sec, 8000 mAh is eight amphours, eight amphours times twelve volts would be 96 watthours, not 29.6. What gives?"
    What gives is, a Li-ion cell isn't twelve volts, it's 3.7. To make a jump pack, they stack up four such cells, producing a nice car-jumpable 14.8 nominal volts.
    Then they also take the amphour ratings of their four 3.7V 2000 mAh cells, and add those together too, to come up with the advertised "8000 mAh".
    Not so fast, though. When you go combining cells, you get to add together the voltages, or add together the currents, but not both. These guys put the cells in series, so the voltages add up, making 14.8. But a series string of four 2000 mAh cells is still 2000 mAh, not 8000. And 2000 mAh times 14.8 V is 29.6 Wh, the honest number on the tiny label on the back.
    In other words, the advertising for jump packs is totally sketchy, but it's not just this one manufacturer, they somehow all agreed on doing it this way. Or the first one to market did, and the others had to copy to compete.
    When you know that, suddenly it's not so surprising that these might be 25% the cost of a Dometic battery that honestly gives its amphour rating at rated voltage. After all, these are 25% of the battery.
  17. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Thanks for explaining it all here. I also had noticed that there must be some interesting "convention" (LOL) being applied here with the specs, but not having one of these devices, was not able to get down to the answer as you have done.
    What you show here makes exact perfect sense, and I am sure it is right. And yes, literally 100% of everything else on the internet about this is wrong (but not according to "convention"). And hardly anybody knows or understands.
    BTW, when I first noticed the discrepancy, I wondered whether they were citing the mAh capacity at a 5V level for the USB power pack functionality. But no, that did not look right either, so I was still wondering what they were doing.
    LOL on the convention - reminds me of how the computer hard drive manufacturers eventually got sued class action style for pretending not to know the difference between a GB and a billion bytes, etc. Of course, this battery convention scam is far more distorted than that.
  18. ChapmanF
    19,025
    On the other hand, after venting the obligatory indignation at the advertising, even a 29.6 watthour thingy that sits in my glove box, fits in my hand, and can start my car (even somebody's old decrepit van one time) is still pretty cool.
    It's just a matter to be aware of, when comparing the numbers to something else.
  19. geedub
    geedub Member
    127
    82
    Flordia
    I appreciate the feedback. I just ordered a fridge and I'm trying my best to understand the power situation.
    What does it mean to have less stress on the main 12v battery? Will it wear out sooner? If that's the case, I can factor that in as part of the cost of going without a 2nd battery.
    It's not likely that I would forget and turn off the car, but I'm fairly confident in Dometics claim that it will shut down the compressor when the battery reaches 11.4 volts. Even if that failed I plan on getting a jump pack.
    About "more amperage, power"; I'm thinking about getting a 1000W pure sine wave converter, which I've read is fine with the Prius main 12v. Is it the case that with an additional 12v the car will cycle on less frequently? That seems like a plus...
    Anyway, I'm not doubting what you say, just trying to get an accurate picture. Thanks!
  20. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    The Prius battery was designed to keep power to the computers, unlock the doors, etc.,
    and tell the hybrid system everything is "okay" for it to start. Then the hybrid battery charges
    the 12V battery, and runs all the 12v items. You don't need a high amperage battery for that.
    I don't believe it was designed for the heavy load of a refrigerator.
    A second battery, that will handle that load would be the best idea. I don't completely understand
    all the "load" details, I just know you need the right equipment for the job.
    You can get them for $100-150. And they do a better job than the Prius battery.
