Second set of wheels for snow tires and TPMS Sensors
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rpg51, Sep 22, 2012.
  1. rpg51
    rpg51 Member
    200
    Vermont
    I have a set of OEM wheels from my old Gen II that I plan to use as second wheels on my new Gen III for snow tires. My question relates to the tire pressure monitoring system (TPMS). Is it necessary that I install TPMS sensors on these second wheels? Or can I run without as I did on my 2008?
  2. Mendel Leisk
    38,705
    You don't need the tpms on the extra rims, the whole concept is just a sink hole for money and hassle.
    When I got snow tires for ours, I ended up getting them mounted on black steel Corolla rims, through a Toyota dealership. Even though our car came with the 17" low profile tires, I went back to 15" for the snows. They asked if I wanted TPMS installed on the snows, I think while shaking their heads, LOL.
    The only downside is a little light comes on in the dash, the tpms warning. It's very unobtrusive.
    FWIW, here's what I used:
    Corolla steel rim, part no: 42611-02471-SW
    steel rim lug nuts: 90942-01007
    Even they weren't sure at the outset if it was compatible, but they thought it would be. In light of this, and since they're price wasn't that far above Costco's, I let them do the whole package (used Michelin X-Ice, in 195/65R15).
    The steel rims were $70 each (likely inflated Canadian price). We'd just purchased the car, and winter was coming (yeah right, I don't think it snowed once that year).
    The lug nuts weren't strictly necessary; I believe the OEM chromed nuts would work, but look a little awkward on plain steel rims. The above mentioned nuts are just galvanized, open-ended utilitarian nuts. Using them will at least preserve the OEMs.
    When I approached the parts department of the dealership we bought from, they were telling me the Prius was a "flagship" vehicle, and no steel rim was avialable. I canvassed a few other dealerships, and one of them came through with this Corolla rim solution.
    Anyway, this is all immaterial if you go with your second gen rims, assuming they're compatible. Just more info/options.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Quick question- do you run snow tires on all 4 wheels- or just the front 2 on the Prius.
    I've had 4wd cars/SUV's for so long now (23+ years) I forgot the procedure for snow tires :giggle:
  4. rpg51
    rpg51 Member
    200
    Vermont
    All four. That is my practice anyway here in Vermont. Don't think it is a great idea to mix tires front and back in any event. When I bought my first Prius it was a bit of any eyeopener as far as issues driving in snow here in Vermont. There are situations you need to avoid, and limitations you need to keep in mind. Put is this way, I have a 4x4 pick up for the morning after a big storm. If I didn't have it I would be waiting for the plow to move the snow before leaving for work which around here can mean all day.
  5. ny_rob
    1,968
    813
    L.I.- NY
    Thanks!
    This winter I'll still have access to my Honda CR-V for snow days, but my daughter gets that car next year (after completing driver ed. etc..) and I'll have to use the Prius year round after that. I'm a bit concerned about snow after so many years with 4WD/AWD vehicles.
  6. rpg51
    rpg51 Member
    200
    Vermont
    Well, I grew up in Fairfield County so I have a feel for your conditions on the Island I think. You will be fine 99% of the time. The issues are real but I think greatly exaggerated. I find that the only issues I have is when it is a fresh snow over 6 inches (and this is because the vehicle is low), when I need to accelerate quickly at an intersection to pull out into traffic and it is slippery (wheel spinning shuts you down) , and when I have to climb a long steep slippery hill - wheel spinning can shut you down. But you do learn tactics to minimize all these issues and so really it comes down to the morning of a storm and moving in deep snow. I don't think on the Island you will have much problem at all. I do carry a small plastic shovel and a tow strap in case I get plowed in or something but in 4 years here in Vermont I have not once used them.
  7. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Local tire dealers told me that new government regulations prohibit them from installing wheels without TPMS on any car that has that feature as standard.
  8. rpg51
    rpg51 Member
    200
    Vermont
    Yea, I just bolt them on myself
  9. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    I believe they are selling you baloney with your tires. There are tire dealers out there that will install wheels without TPMS. I had no problem finding one.
  10. car compulsive
    741
    274
    Michigan
    This was the line at the corporate tire stores I frequent, Discount Tire & Belle Tire. I know government regs changed in this area and who knows, maybe the corporations are playing stretching the regs to upsell or cover themselves legally.
  11. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    Not sure if it's different in Michigan but I live in Edmonton, Canada and the Costco here has no problem installing the wheels without TPMS. In fact, the lady at Costco even mentioned that some of their customers tape a little bit of black tape on the display to cover up the yellow TPMS light that turns on. =P
    But yes, pretty much all the tire dealers in Edmonton wanted to have the TPMS installed as well. That's why I'm getting my tires changed at Costco. =)
  12. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Use black duct tape to cover the tpms light till you go back to summer rubber.
  13. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I run 15" steelies w/o TPMS sensors during the wintertime. I learn to just ignore the light. It will flash for a bit, then stay on solid for the duration of the trip.
  14. car compulsive
    741
    274
    Michigan
    Belle Tire replaced all 4 of my TPMS sensors on my summer wheels and the light is now out. We'll see if it lasts the rest of the fall before the winter wheels / tires go on at the end of November.
  15. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    There is a 5 min hack to disable the light. Do a search and you will find it.
  16. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    All 4 wheels.
  17. hlunde
    hlunde Member
    419
    74
    Toyota is pretty silent on recommendations:
    -- tire size?
    -- speed rating (Q, R, S, T?)
    -- winter wheel part numbers?
    -- winter inflation pressures?
    -- factory winter tire packages offered by Toyota?
    I am unaware of any of the above.
    Also, I don't believe that Prius TPMS system is"self learning" when sensors are changed.
    You're really on your own.
  18. Judgeless
    1,821
    255
    Cleveland, OH
    All this is heavily documented on other threads.
    Every time you change your rims with a different TPMS sensor you need to take it to the dealer so they can match the sensors with the car. It only holds one set of 4 rims in memory. This means twice a year you need to pay the dealer. You can buy special tools to get around this but they are not cheap.
    The 5 minute wire hack is the best solution.
  19. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Tire Pressure Monitoring is a nice safety feature to have. It alerted me to an industrial staple in my sidewall and got to a Les Schwab Tire Center for a free fix vs. disabled on the road. Especially true in winter driving.
    I'm just changing the tires, using the same rims and avoiding costs of additional wheels and the TPMS issue.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    to disable it or to fool it? I went through the threads and didn't see a way to disable.? Could you be so kind to point us?
    [edit] - found the information here. Thanks Judgeless
