Second thoughts . . .
Discussion in 'Gen 3 Prius Main Forum' started by Doc Willie, Jan 17, 2009.
  1. darelldd
    6,059
    389
    Northern CA
    I buy when there is a plug - with significant battery-only range attached to the other end of it.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Okay, here is a style question for all of you. I am looking at a black 2010 (as black is the only real color for a Prius :p), but have mixed feelings about the color of the leather. Our current 2006 is black with light grey cloth seats. It looks good. I suspect the Misty Grey Leather is close to the same color. What I don't know is how dark the Dark Grey Leather is. So here are my questions:
    1) Did anyone get a photo of the Dark Grey Leather interior? If so, I'd love to see it.
    2) What are your thoughts about a black car with Dark Grey Leather? Obviously it will be hotter in the sun, but do you think that would be too much dark?
    Thanks,
    Tom
  3. Tideland Prius
    16,678
    I don't have very many interior pics of the Blue Ribbon Prius so I didn't get many shots of the Dark Grey leather but I do remember how it looks like.
    Dark Grey is probably the same as Charcoal on other cars. It's definitely not a black interior but a nice classy, darker interior.
    I like the dark grey interior and will probably be my choice (I currently have a beige/black interior) but my exterior choice is lighter.
    I would probably get the Misty Grey so you'll get a mixed of light grey (so light, it's nearly white) and the dark grey door panels and centre console lid. i.e. it's about contrast.
    I'm trying to think of another Toyota with a dark grey leather interior.. I'll let you know if I think of a vehicle so you can check it out in the showroom.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just looked through my shots, apparently I didn't take any interior shots of the blue w/gray....but this one shows the color fairly well.
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The questions still stands. What could Toyota get if mpg were the focused goal and the 2001 Prius or Yaris size was targeted?
    This is not a complaint about the 2010, since you are right, the 2010 is definitely a mainstream car and is designed right for that purpose.
    I ask since I use the 2001 Prius as a commuting car for a single person every week to the same place carrying only me (past the gas station). The inevitable swelling of cars from model year to model year seems to be happening to the Prius as well.
  6. Tideland Prius
    16,678
    Here lies the iQ's purpose =)
    1.0 litre or 1.33 litre gas engine with a 1.4 litre diesel engine. The 1.0 litre will be the second most thrifty car (behind the prius of course) in the Toyota lineup.
  7. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Our goal is to go fom 2 vehicles to 1. If everything works out the new 2010 will replace the 07 Prius and an 06 TDI.
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Can anyone point to Toyota's announcement of the basic curb weight for the 2010 Prius?
    I've seen the mention in some article of it being '100 lbs' more, but the source seems shaky.
    btw, that Blue Ribbon or whateva .... is much like Spectra Blue.
  9. daniel
    14,487
    1,519
    Spokane, WA
    My Xebra may be for sale in a couple of months. I hope to have my EV Porsche by then.
  10. Doc Willie
    1,717
    144
    Out there, somewhere
    The solar sun roof would appear to be the perfect solution to the dark interior temperature problem.
    Appearance wise, I have seen plently of black cars with dark interiors. Some look better than others, but it is mostly a matter of personal taste.
  11. catsbox
    catsbox Member
    295
    Bellevue, WA
    I'm due for a trade in and was having second thoughts BEFORE the 2010 was revealed. I like what I saw. Not to mention the fact that my state is eliminating the sales tax for the Prius this year. That is a huge savings in and of itself. I think I may just go for it, will need to test drive first. I absolutely love the moon roof.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    problem is that few inches of space is not where weight is... batteries, crash protection, options are what brings the weight up. so you end up having to use aluminium like prius, and it ends up being almost as expensive vehicle, but much smaller in size (and hence less usable)...
    iQ, while great, is not that much more efficient than Yaris, and Yaris is a lot more usable than iQ.
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I have both a 2001 and 2007. When you put the two side by side, there is no mistaking that the 2007 is a lot bigger, but the whole Engine/HSD takes up the same amount of space as the 2001. Following the initial reports, the 2010 HSD looked to be lighter and not take up more space than the 2007. I was just seeing if someone had a good idea of what the difference between the 2010 system in a "2001 body" mpg would be as a thought experiment. Nothing more. No complaints or desires implied.
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok. another post says that they just started it Jan 1, 2009 and it will run 3 years... sooo, how long has this sales tax incentive been going on? was it available for vehicles purchased in 2006?
  15. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    When cruising, most of the engine power is required to overcome air resistance - drag. If you look at the drag equations (Wikipedia), you'll see that the only factors in calculating high-velocity drag are the density of the air, the velocity of the vehicle, and the drag area. We know that the co-efficient of the 2010 Prius is lower than that of the 2004 (0.25 vs 0.26) and that the 2001 Prius was 0.28, but I would assume the nominal area is larger in the newer cars, so the actual drag area is roughly the same (I can't find any drag area numbers for the 2001 car). The actual 'area', measuring by vehicle height x vehicle width, is 5% greater for the 2010 over the 2001 model, but the 2001's drag coefficient is 12% bigger.
    Of course the tests also covers acceleration, which will require a lower force for a lighter vehicle (famous equation: F = ma, force = mass times acceleration, so for a given acceleration, the force needs to be greater for a greater mass). The mass of NHW20 isn't substantially greater than NHW11, though: the brochure I have states 1300kg for NHW20's kerb weight while this Aussie press release states 1250kg for NHW11. That's 4% heavier.
    In sum, I'm not sure that fitting the 2010 drivetrain into NHW11's body would give much benefit. A theoretical new body of the size of NHW11 - about two inches narrower and two inches less height - with the 2010's drag coefficient would likely give some benefit to highway mileage. However, it would be at the cost of internal space, as new safety technologies have required greater amounts of space in the doors, etc.
  16. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    I echo Efusco "I want a PHEV...period."
  17. daniel
    14,487
    1,519
    Spokane, WA
    No. Car must be purchased new on or after Jan 1 2009, and meet certain criteria. It's uncertain whether vehicles such as Zenn and Xebra would qualify, and conversion cars apparently do not.
    From the page you cite, the coefficient of drag is another factor. I.e., two cars with the same area can have very different amounts of drag at the same speed and air density.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well im certain that unless i "repurchase" my Zenn, it qualifies for nothing...
  19. daniel
    14,487
    1,519
    Spokane, WA
    The car must be purchased new to qualify, and I think it must be purchased from a regular car maker; i.e. conversions would not qualify. I'm not sure of that. But I think they went to great lengths to exclude everything but new cars from major car makers.
  20. catsbox
    catsbox Member
    295
    Bellevue, WA
    Buyers of low-fuel cars get a sales tax exemption
    "The tax break, which takes effect Jan. 1, applies only to new vehicles. It also only covers cars and trucks getting at least 40 highway mpg, which includes the Prius and hybrid Honda Civic, but not the Toyota Camry or hybrid SUVs." and
    "It does, however, appear to cover what are called "neighborhood electric vehicles" or "medium speed vehicles" sold by The Green Car Co. The cars are street legal, but don't go faster than 35 mph. It also applies to vehicles running on alternative fuels, such as natural gas, propane and hydrogen, though they're rare."
