Securing charger to wall
Discussion in 'Prime Plug-in Charging' started by bsma4, Mar 17, 2018.
  1. bsma4
    bsma4 Junior Member
    Gurnee, IL
    The outlet in my garage is half way up the wall. What is the best way to secure the charger while plugged in, but not permanently? Heavy duty Velcro?
  2. Mark57
    2,945
    2,736
    OK
    Some have made a simple wire hanger using the two holes on the charger and then hang the charger by that wire via nail, or picture hanger so there is no weight on the outlet it's plugged into. Easy to unplug and take it with you.
    49,379
    i tried the velcro without much success, and wound up with a hook and small bungee.
  4. stuyguy
    stuyguy Active Member
    168
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    Hook and wire. Switch controls only the outlet that charger is always plugged into
    benagi likes this.
  5. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    Here's what I did. I used a couple long nails with small heads (smaller than the holes on the charger). So while the charger is held in place by gravity, if you want to you can just pull it away from the wall (or, in my case, a post in the middle of my garage).
    Old Bear and Mark57 like this.
  6. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    As they say, "It's so simple that only a child can do it."
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    If the charger plug in question is like the picture in post #4........
    Then you should NOT have to worry about it.
    If the plug feels loose in the outlet, you NEED a new outlet because it might not be making a good connection.
