Securing the charging cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ThatTallGuy, Mar 14, 2012.
  1. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    so many worry warts ..whos going to want to steal an evse..& what use would they have for it
  2. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    To sell it and make $600.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Saw a Volt in an EV stall at the long term parking lot at San Francisco airport plugged into the 110V. All I could think about was the person was leaving >$500 cable to get some $4 worth of electricity. I parked in the regular stalls and left my EVSE in the trunk. Not worth the gamble to charge in public places.
    PriusC_Commuter likes this.
  4. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Most of my public charging is at a Level 2, which has it's own cable. On the rare occasion I am using my Level 1, I use a padlock with a long hasp to secure the cable to my Curt hitch.
  5. lensovet
    2,615
    496
    Burlington, NJ
    For the Prius in general this math never pencils out. I highly doubt the driver did this for any sort of money saving reason – I know I certainly don't.
  6. kenmce
    kenmce High Voltage Member
    1,551
    524
    NY
    Trade that bad boy for a bag of crack, take five minutes tops, watch this.
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Just loop your charging cable behind the rear tire and drive over it. That will definitely secure the cable, unless somebody wants to jack your car.
  8. Jimbo69ny
    712
    107
    Ithaca, NY
    You don't want to drive your 3000lb car over your charging cord. That's a bad idea.
  9. Rebound
    3,996
    2,645
    Portland, OR
    Meh. It's only 750 pounds per tire.
  10. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Driving over the cord to secure the EVSE was the actual recommendation given to me by the Priestess of Priuses. :)
  11. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    I just leave it at home. As someone said with 12 miles EV, what is that 70 cents of gas. If I do charge I look for a level 2 station.
  12. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    The bigger concern for me is that I have been unplugged several times at a public charger - and NOT by BEV's, which I would excuse. Once by a Fusion and once by a Volt. Nowadays when I charge at that location (one of the local malls close to my work), I put my little luggage lock through the handle. If people using that charger want to be d-bags, I can accommodate. Clipper Creek chargers make it really easy to determine whether a vehicle is finished or charging, so the offenders clearly knew what they were doing.
  13. GregP507
    GregP507 Senior Member
    3,002
    481
    I'm annoyed because the GFI on the L1 charge cable is only about a foot from the plug. Most outlets are about 3' off the floor, therefore all that weight bears down on the plug when it's plugged in. Just try to mention using an extension cord and you'll hear from someone about how unsafe that would be. So what's safe about a plug with a lot of downward strain on it, due to the heavy GFI bearing down in it? What genius designed that?
  14. Greenwave
    Greenwave New Member
    Turbo cord is a cheaper replacement and it has 120/240..
  15. MendyK
    MendyK New Member
    Seattle, WA
    2020 Prius Prime
    I noticed that this thread is several years old, but I wanted to add an update. I secure my charging cable by using the transportation hook that came with my car and a padlock. I own a 2020 prius prime. The transportation hook is in a black plastic bag that is in the same cubby/trunk space that the charging cable is stored in. Just pop on of the four bumper covers off and screw it in place. Then secure the cable to the loop using a padlock. My car is street parked, so the added security gives me more peace of mind.
    I've attached photos.
  16. kenmce
    1,551
    524
    NY
    Simplicity itself. Nice.
