Seeing P0A80 code, but unable to see P30XX module code
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Kat Li, Jun 25, 2025.
  1. Kat Li
    Kat Li New Member
    Seattle WA
    2014 Prius c
    I’ve got a 2014 Prius C with the original hybrid battery and about 137,000 miles on it. Recently, I got a P0A80 code (“Replace Hybrid Battery Pack”), and I’m trying to pinpoint which specific modules might be failing.
    I’m using both the Autel AP2500E and the Dr. Prius, but neither is showing any module-level codes (like the P30XX codes that would normally point to the bad modules).
    Maybe I’m just not using the tools correctly and need to dig into a specific section to see those module-level codes? I did Google to research this but have not been able to find any definitive answer. I am a novice at this. Any tips or advice would be super appreciated!
    Davidayalala340340 likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,660
    1,061
    South Central PA, USA
    Have you or do you reset the P0A80 code after it occurs.
    Have you at any point disconnected the 12v battery after getting the P0A80 code?
    To get the P30xx battery block code, you should not clear/reset any trouble codes and do not disconnect the 12v battery.
  3. Leadfoot J. McCoalroller
    8,270
    7,775
    Pennsylvania
    2018 Prius c
    I recall that the P0A80 error only has one possible sub-code anyway- so there isn't really any more detail to expose in terms of why the car thinks the pack is bad.
    You can do your own investigation by reading voltages and temperatures and possibly work out for yourself which modules are weakest, and probably get some further utility from that pack by replacing them. But there isn't really a way to ask the car to "show your work" once it declares a P0A80.
  4. Brian1954
    2,660
    1,061
    You are correct. There is only one INF (sub-code) for code P0A80, which is 123. But if you do not clear/reset the P0A80 code and drive the car long enough, you should get a P30xx code, which tells you which of the blocks is becoming weak. Example, P3011 is for "Battery Block 1 Becomes Weak" , ......, all the way up to P3020 for "Battery Block 10 Becomes Weak".
    #4 Brian1954, Jun 26, 2025
