Seeing when Open Loop to Closed Loop happens
Discussion in 'Gen 2 Prius Main Forum' started by pasadena_commut, Jan 18, 2026.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,040
    943
    Southern California
    Does the car give some clue when it shifts from Open Loop to Closed Loop? That is, some way the driver could definitively tell when that happens? On our old Protege5 I could tell by a change in the idle, but that only works if the car is sitting still, it would be nice to have this information when the car is moving.
    Failing that, any idea which of the huge number of displays available in Torque Pro (with the Prius PIDs added) will show this?
    I'm curious because the car seems to be slow to warm up, as judged solely by the change in MPG on the bar display. Might or might not be correlated with the OL to CL transition. Seems like it should be.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Generic OBD2 data should have a PID such as "loop status" (OL or CL, open or closed, etc).
    Or look to see when STFT starts moving around.
    As far as actually "warming up", you can monitor ECT (engine coolant temperature) to see if the thermostat is working correctly. Most failures I see are the stat opening early. If it gets real bad then the ECM should set P0128, but that's "should".
    You can check ECT on an extended 50-60mph cruise (ICE running continuously)on a cold day (turn heater off) - ECT should stay around 180°F. Airflow should remove heat faster than the ICE can supply it.
    Or start the (cold) engine and monitor ECT while keeping throttle applied in park so that ICE stays running. ECT should fluctuate after CHS operation then climb steadily, before "leveling off" around 180°F. Once the radiator is fully "hot", then ECT will go up again. Before the stat opens, the radiator core should stay cold.
  3. pasadena_commut
    3,040
    943
    Southern California
    Used Torque on the return trip. Got on the highway and drove along occasionally checking coolant temperature and closed/open. It was 65F outside, driving around 65-70 mph, and it took almost 15 minutes before it went to closed loop. Coolant temperature hung for quite a while around 181F but then finally got up to 185F, at which point it went to closed loop. When the car turned off the highway after about 35 minutes, and had to wait 30s on the off ramp it fell rapidly to 180ish and went to open loop. After that on the rest of the trip after a short rest stop (15 minutes) it would quickly get back up to 185F and go into closed loop, like in a minute or two, not slowly like at the start. This even though the ambient temperature in the central valley was cooler, at around 50F. The car only went over 185F when going up a steep sustained slope. The highest I saw was 192F. It might have gone higher going up the grapevine, but I couldn't take my eyes off the road there to check, as there was too much traffic. Sitting on I5 cruising along at 71 mph, it was like the coolant temperature was nailed at 185F.
    I bet the slow initial warm up was because the car had sat for a week in an unheated garage (mean temp, not sure, 45F?) without being driven, and had only been driven 5 miles (two short trips of 2.5 miles) the previous day. The thermos tank was likely full of cold coolant at the start.
  4. pasadena_commut
    3,040
    943
    Southern California
    A couple of days ago a new water pump belt was put on, but didn't have a chance to drive the car until now. Took it on a roughly 8 mile each way trip, and had the wife watch the ECT on Torque Pro, so if the belt fell off for some reason odd reason there would be more warning than waiting for the ICE to overheat. (Wasn't expecting the belt to fall off, and it did not, nor did it squeal or misbehave at all.) The coolant temperature got up to 185F (ish) about half way to the destination, then we paused (car stopped but READY in P, AC off, windows down) at about 7 miles so she could buy a couple of Filet of Fish sandwiches, and after that I had her check for closed loop/open loop. For some reason it didn't go to closed loop in that mile even though the ECT rapidly got back into the same range. Paused again at 8 miles (car READY, in Park, A/C running) and on starting up again it quickly went to closed loop.
    The car seems to be taking an awfully long time to go to closed loop following being off overnight, but once it starts doing that, it does so quickly even after a 5 or 10 minute stop with the car turned off. Unlike the first trip where I noticed this, it was quite hot today, something like 80F when we left, and not very cold last night. So today the ICE didn't have the excuse that it was really cold. I need to check this further, double check that the ECT gets up to 185 from being off overnight without going to CL from OL, until it finally does. What could cause that delay if the ECT is up to temperature? This was city driving, but the first time it was highway driving. I can imagine the catalytic converter or oxygen sensors might not get up to temperature in stop and go very quickly, but surely they would have on the highway.
