Seeking Advice: Used Prius with openable moonroof
Discussion in 'Newbie Forum' started by ABarnam24, Jul 8, 2024.
  1. ABarnam24
    ABarnam24 New Member
    Berkeley, CA
    Hello dear forum!
    You have come up many times in my searches, but I have not found answers to this particular question.
    So I've made an account properly and here I am. Thank you for all the information here!
    I would like a used prius with an openable moonroof.
    Could be any type of prius: prius, prius v, prius prime, or prius c.
    At first I was set on the prius v, only to find the moonroofs are all fixed to my knowledge
    How on earth do I find which years/models/trim levels have an openable moonroof as an option?
    Hopefully having this information will help me find the used prius of my dreams!
    Amira
  2. ABarnam24
    Berkeley, CA
    Also, I can't figure out how to edit my thread! But I also meant to ask -- is this even the right forum to post this in?
  3. Tideland Prius
    16,680
    Hello and welcome to PriusChat!
    This forum is fine given you’re asking about multiple generations.
    The Prius c was available with a moonroof. IIRC, it’s was on the Three and Four trim levels as an option.
    For the regular Prius Liftback, a solar panel moonroof was offered on the Gen 3 (2010-2015 MY). It came with a regular glass roof in the front half of the roof and a solar panel in the back half. It was available on the Three and Four trim level as a “Solar Roof Package” or “Deluxe Solar Roof Package”.
    A regular moonroof is offered on the Gen 4 Prius on the higher trim levels as an option.
    A tilt/slide moonroof is not available on the Prime.
    ABarnam24 likes this.
  4. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    Shown as available on Prius c Three and Four trims
    Tideland Prius and ABarnam24 like this.
  5. ABarnam24
    Berkeley, CA
    This is so helpful, ty!! Now I know the language tilt/slide. That's what I want!
    I take your post to mean both the Prius c and Gen 4 Prius had regular tilt/slide moonroofs....
    Gen 3 had a solar portion... I will try to find some YouTube videos to check these out.
    Does anyone have suggestions on strategies of how to find this in the used car world?
    My current strategy: I've been all over carfax and carmax.... Carfax I can't search by moonroof/sunroof.
    All suggestions welcome!
    Tideland Prius likes this.
  6. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Solar Panel Moon Roof options were available on most higher trim levels as an option or package for Gen 3 years 2010 to 2015 on Prius, Prius C
    Prius V models look to me like the Solar Roof option that is currently available of the Gen 4 and Gen 5 Prius and it doesn't open to the outside..
    That's the best I can figure it out, and I've had to change this post at least 4 times already
    ps and slightly offtopic: The "Car Care Nut youtube channel" has an hour long video on the "Panoramic Solar Roof" explaining a possible issue and repair. It's somewhat similar to several priuschat posts regarding issues of rainwater draining and seal leaking issues with the Gen 3 solar moon roof.
    #6 vvillovv, Jul 9, 2024
  7. ABarnam24
    Berkeley, CA
    I appreciate all your effort!! I have no idea how you even figured this out, I did lots of searches and wasn't coming up with anything.
