Seeking maintenance recommendations for 2012 Prius five
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Traveler2025, May 31, 2025.
  1. Traveler2025
    Traveler2025 New Member
    Bay Area, CA
    We are seeking the wisdom of the crowd on an issue with our 2012 Prius five.
    Our goal: We've found it to be the perfect car for us, and we are willing to invest in it to maintain the car in excellent working order for as long as possible (we actually prefer it to newer models). Among other praiseworthy features, the design is such that I at 6'5" can comfortably sit without my head hitting the roof (which it does on all the newer Toyota models we've tried), and my wife despite being very short has excellent visibility in each direction thanks to the older window design. It is a unicorn in this regard.
    Relevant stats: The car is presently used for a short distance approximately 5 days per week (10-20 miles), and a longer distance (~900 miles) three or so times a year. It has just over 200,000 miles on it total, has never been in an accident, and it has had all recommended maintenance on schedule over the entire life of the car (we have owned it since it was new). It had a new hybrid battery system installed at 140,000 miles under warranty, and has recently had new brake pads and struts/shocks installed, as well as the engine treatment and fuel injection services done, in addition to the 200,000 mile service.
    Here is the issue: a few weeks ago, when starting the car to go into work first thing in the morning (last driven the afternoon prior), the engine made a loud, very dramatic knocking sound for 10-15 seconds, before the sound quieted and went away. This all happened while the car was turned on but still stationary in the driveway. It has not been replicated since.
    We took the car to our local dealership and asked them to check to see if they could identify the cause — not being able to replicate the sound, of course, made this more difficult. We did ask them whether it would be a good idea to flush the EGR system and clean the intake manifold, and the answer was a shrug from the guy they had talk to us about it. Here, however, is what the tech wrote in the report (we were not given the opportunity to talk to him, and only saw this on the way out the door):
    "No engine or hybrid codes; removed wiper cowl assembly; removed all spark plugs; pressurized cooling system, boro-scoped all 4 cylinders, no internal coolant leaks seen. Performed cylinder leak down test on all cylinders. No pressure rise in cooling system, will recheck again cold but may have EGR [sic], carbon deposits (noticed excessive carbon/soot residue in tailpipe) injector or other issues -- cannot confirm."
    They also found evidence of general mouse activity in the engine liner and recommended we use a spray to discourage them.
    The dealership person we *were* able to talk to offered us no advice as to how to move forward when asked, nor did they suggest any preventive maintenance when we asked specifically about it. The response was only to tell us to return if the engine knocking happens again. We, however, would prefer to prevent it from happening again.
    Our question for you all is: if your goal were to maintain this car in good working order moving forward, and you were willing to invest to do so, what would your next steps be?
    Thank you!
    52,863
    congrats and welcome!
    watch this video:watch
    and read through some threads:736916237
    consider an oil catch can:
    736918296
    keep in mind that the very expensive brake actuator can go out around now.
    do oil changes at 5,000 miles, and frequent coolant changes. inquire into the waterpump speed software tsb.
    keep a close eye on the oil to determine how many miles per quart you are burning.
    all the best!
  3. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    In some cases early morning "cold start" engine knocking (misfires) can be completely random one-offs, but in my experience it was usually cold weather.
    If it happens regularly then the issue is most likely a head-gasket leak which causes coolant to leak in the cylinders and cause misfires. This is the achilles heel on this model and is also the downside of your purchase because if you are on your original head gasket then it's in the goldilocks zone of failure (after 250k miles is where it becomes rare to not have had issues). If you poke around the forum you'll see it's a tale as old as time. Dealer prices for this are generally catastrophic, but in some cities you can find specialty shops to do it for more reasonable prices. Even if this does turn out not to be your situation it's something to think about.
    Hopefully it's the random one-off thing.
    Yes you probably need an EGR cleaning but that's not your issue with the engine knocking. If you go through the EGR cleaning process before evaluating the reason for the cold start knocking then you run the risk of wasting time/money. If it doesn't happen for another week or two then think about the EGR stuff.
    For now, just pray it doesn't start happening more often, and that the head gasket gods give you many more years.
    Is the car under dealership warranty or anything? If not, I would avoid the dealership except for parts that you pay someone else to put in.
    Just my opinion as a random non-expert forum dweller.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Damn, car is a unicorn because tall and short people can see with this window design.
  5. Traveler2025
    Bay Area, CA
    Just wanted to thank everyone for the welcome and the wisdom, particularly the videos!
    The sound has not recurred, and we're keeping fingers crossed. We'll update as warranted.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    If you don’t have HG issues now, I will assume it’ll come back in 80k miles or so. My first sign of morning rattles started after 200k miles, I thought it was condensation in the engine some how, it was fine till I hit 284k miles was when the rattle was louder and caused a check engine light for cylinder 1 misfire, so I erased the code, drove for 300 more miles and the misfire came back, so I stopped driving it.
    the next day the rattle was more consistent so I didn’t want to blow the engine or cause a bent piston rod or worst, clogged up the cat. So I ended up replacing the HG and no far, it’s running nicely.
  7. Mendel Leisk
    42,355
    You’ve got early head gasket failure symptoms. Get on it ASAP, starting with a borescope inspection of the combustion chambers, preferably the morning after driving the previous day, and with cooling system pressurized (to accelerate coolant leakage into cylinder).
    the only way to avoid this is regular, thorough cleaning of the EGR system, ideally every 50k miles.
    more info in my signature. (On a phone turn it landscape to see signatures)
