Featured Seems Draining your Lithium Ion Battery is really bad
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by drash, May 5, 2025.
  1. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    The transition to Sodium-Ion is already underway for Seagull... The vehicle was specifically designed for Sodium-ion and the first ones were LFP in order to meet difficult deadlines, but most of that is already behind them now.
  2. PriusCamper
    13,475
    5,441
    We're both right... One of us is looking forward towards what is going to happen next... The other one is looking backwards and trying to argue that the success of the past won't allow the future to happen. It's a progressive view versus a turn back the clock anti-modernist view.
    Or even better stated is this article about Tesla: "...as Tesla remains stagnant, other manufacturers are racing ahead. BYD, Hyundai, and General Motors are launching more affordable models with advanced technology and aggressive marketing strategies, winning over many who once trusted Tesla. And of course, this massive loss of loyalty is not going unnoticed at the American giant. It almost feels like a seasoned senior is being overtaken by a newly recruited rookie." Farewell to Tesla's golden era - Elon Musk admits he has run out of options as the company faces imminent collapse
    When it comes to how Tesla finances things it makes them particularly vulnerable... They're the opposite of what Apple has done by sitting on a massive pile of cash, as well as getting their parts and products exempt from the trade war. Not even Elon trying to be best friends with Trump is putting him in a position as favorable as how Apple is managing its business.
    #22 PriusCamper, May 5, 2025
  3. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Well that was the rumor that some would come with a smaller sodium ion battery in 2022. Its 2025, and I have not heard mention that they have sold a single one. I'm sure they have some running as test mules, but maybe it didn't perform as expected.
    Try again. Some small manufacturers have put out a token number. BYD and CATL are producing sodium ion for fixed storage where weight and size are less important. Let me know when your mirical happens, until then don't name call or pretend those of us that don't have your magic crystal ball are racists against the Chinese. Why do you hate Texas and Tesla so much?
  4. hill
    9,041
    If I were his ambassador, I would say, & rightly so, it's because he's a never Trumper, whether Trump does good or not. An that's ok as we're a multi party nation.
  5. ChapmanF
    19,060
    In #16 I specifically pared back the verbiage to the two contradictory claims on current fact that you and austingreen had made, as a way of maybe cutting through some of the sloganeering.
    That was the idea anyway.
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Why did scientists do this research only now?
    I first discovered a swollen battery on my mobile phone about twenty years ago.
    And yes, the process of battery combustion in a phone is less effective than in a car.
    austingreen likes this.
  7. bwilson4web
    16,552
    Is it OK if we wear out our current inventory of batteries? <GRINS>
  8. Trollbait
    12,832
    BYD started building a sodium ion plant a year ago. CATL started this year.
    BYD breaks ground on its first sodium-ion EV battery plant
    https://www.ccn.com/news/technology/catl-sodium-ion-battery-rivalry-byd/
    CATL has mixed chemistry battery packs that could have Na-ion with Li-ion. Don't know which EV models use them. Otherwise, I'm only finding two EVs that use Na-ion. They became available last year and are both city cars. These are iQ to Spark sized with a top speed of 63mph. The Na-ion trims have noticeably shorter range than even the LFP trims; one is 93 miles on NEDC.
    First sodium-ion battery EVs go into serial production in China - electrive.com
    JMEV EV3 - Wikipedia
    I'm not finding production model specs for the other one.
  9. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I know the chemistry varies, but I have had some success with getting lithium cells to start charging by giving them a shock charge of over 30 volts. It's important to limit the current so that it won't runaway and overheat. I think it may have something to do with burning out the dendrite shorts.
  10. hill
    9,041
    That almost sounds like running a compressed air hose into an empty gas tank then throwing a match in it - to "clear it out". It may work, or it may go very wrong.
  11. bwilson4web
    16,552
    Hummmm, have you considered using a charged, BAC (Big As Capacitor)? No risk of a thermal runaway and minimize (bur not eliminate) damage to the separator.
    Have you done a charge-discharge of an identical new or working cell versus one you have regenerated?
    The reason I ask is the literature blames the SEI layer for capturing the lithium ions leading to a permanent loss of capacity. There are reports that the cathode and anode may have irreversible chemical changes that lockup the ions.
    For historical reasons, the old NiCD batteries did generate dendrites and I understand it was common practice on aircraft carriers to "burn them out."
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm not sure how your method is any better than using a power supply with controlled voltage and controlled current limits. I have rehabilitated many rechargeable batteries with this method. I set the current limit to about 1 amp. and then slowly increase the voltage until I can see current starting to flow on the meter.
    I'm sure that the battery doesn't have the capacity it had when new, but that wasn't the goal. It was to restore some function to a dead battery that no longer took a charge.
    austingreen and bwilson4web like this.
  13. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    My previous phone was a Samsung Galaxy S9+. An app revealed that the battery was being charged to 4.4 volts, which explains why it puffed up and expanded out of its case in just over a year after I bought it. I then started using a battery saver app that sent an audible alert when the battery charge level reached a preset level I had preset at 85% charge, when I had to disconnect it from the charger. This was intended to extend my battery life by several years. I would have liked the recharging to have stopped by itself, but any apps I found that could do this, required rooting my phone, which I wanted to avoid.
    I was happy to learn that my new Samsung Galaxy S23 had a battery saving feature in the setup which charges the battery to 80% when finished. This is much healthier for the battery, and after 2 years, I haven't seen any significand degradation of battery performance. I do not need the extra capacity that was presumably being provided by the higher charging level.
    #33 Paul Gregory, May 6, 2025
  14. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Samsung seems conflicted in their advertizing. On one hand they criticized Apple for getting rid of the headphone jack, then they did it themselves. They criticized the lack of removable storage and then they did it themselves. The tyranny of "it sucks, but it works," I guess.
  15. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Apparently more people were interested in how a battery performs than in actual cell level issues. And most cell level research was focused on the cathode. the surrounding SEI and the effects of charging. I did some extensive searching on-line and found no other relevant information on this issue. Seems the Koreans were the first to actually examine and identify the lithium oxide issue at the anode because they sat down and watched as it discharged.
    As @bisco asked nobody knows what the voltage level is at the cell when the GOM (guess-o-meter) says 100 miles, 50 miles, or less. You can probably calculate it if you have battery voltage (via an OBD app) and divide it by the number of cells at whatever range level.
    Ah yes, I've had battery swells in at least 3 battery power packs. I'm sure there may be other causes for swollen cells other than the lithium oxide at the cathode issue. The testing at least uncovers an additional limit that we should monitor.
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I consider this to be a dirty trick by phone manufacturers. Setting the charging voltage higher than 4.2V, often 4.4 or 4.5, will give the phone a bit longer life on a charge, but it will seriously degrade the lifespan of the battery. Of course, the chemistry of Lithium Iron Phosphate batteries is lower, around 3.7V maximum charge, but well designed batteries charge to a lower voltage level, reducing capacity, but the battery is likely to last much longer.
  17. bisco
    52,899
    the goal of any manufacturer is to get a majority of product beyond warranty. it's not an easy task, and it's only competition that drives them to improve on that philosophy
  18. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Once you know how detrimental overcharging it is to battery longevity, you can apply various remedies to keep the upper charge limit low.
