Self-parking nearly hit a pick-up truck!
Discussion in 'Gen 4 Prius Main Forum' started by CherylH, Aug 28, 2017.
  1. CherylH
    CherylH New Member
    South Carolina
    Four Touring
    My husband put the new Prius in self-park backup...took his hands off the steering wheel, and the car shot backwards. He hit the brakes when I screamed at him to stop...half an inch from a big truck! What went wrong?
    RCO likes this.
    49,478
    i had the same thing happen in my test drive. the salesman swore it wouldn't have hit, but i was glad i hit the brakes first, and didn't want to risk it.
    RCO likes this.
  3. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    Have you ever successfully used the parking assist feature before?
  4. Bab F
    Bab F Junior Member
    WA
    2020 Prius Prime
    I use it all the time in a usually congested parking lot. The only time I have seen such as described above is when the area was a slope and the car was moving fast. But the car also told me it was too fast and I should apply the brakes.
    CoolPrius and RCO like this.
  5. MichelleStone
    MichelleStone Senior Member
    549
    817
    Mariposa, CA
    I'm still waiting for an opportunity to test mine out. I haven't had one since I purchased the car one year ago. I live in the boonies. We don't have parallel parking anywhere. They are all angled slots at the local market.
    RCO likes this.
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    He should have been riding the brakes. It's an assisted driving (parking) aid. Read your owners manual.
    kithmo, CoolPrius and RCO like this.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Yeah, I don't trust the car to do anything by itself. It doesn't have the intuition that a competent driver has, it doesn't know the intent of the driver, and it can't see everything around it including other cars and the current traffic pattern that it is sitting in.
    Don't let the car rule itself, you won't be able to use it as a defense when you run somebody over or hit another car.
    pilotgrrl, kithmo, RCO and 1 other person like this.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Wow! I'm almost glad my car doesn't have that feature. :sick:
    'LectroFuel, kithmo and Raytheeagle like this.
  9. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    I've used it a few times and it is pretty amazing. The key is knowing how the system works as mentioned above. Check the user manual, watch YouTube videos and test out somewhere that's not busy. You shouldn't need your foot on the accelerator at all from my experience, only use the brake pedal...unless maybe you are at a steep angle?
    The 2007 Lexus LS460 had the self park feature so the core tech has been around for quite some time.
    pilotgrrl and RCO like this.
  10. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Crap...now you have to put that damn phone down to park too. sarcasm
    #10 frodoz737, Aug 29, 2017
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I love it, use it all the time, I haven't had the need to use the parallel unpark assist yet though.
    RCO likes this.
  12. jj3
    jj3 Junior Member
    Four Touring
    I've found that when using the standard parking assist, it tends to offset to the right so I have about 3 feet open by my door. However on the passenger side, there's about 6 whole inches past my mirror to the neighboring car on that side.
    iPad ? Pro
  13. tucatz
    tucatz Active Member
    501
    412
    Manzanita, Oregon
    Four Touring
    you need to have your foot on the brake while using parking assist. The computer controls the wheel, and indicates clearance but the driver modulates the braking.
    Unparking assist (hadn't thought of calling it this) is very useful; i use it all the time. I can wedge myself into a tight space and later get myself out without doing any of numerous wheel twists or worry about scraping bumpers it works great!
  14. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Maybe you didn't let it finish. When using back-in parking it will equally space the car between the two cars if you let it.
    Once it's in the space it will say select "D" to go forward or press "P" to finish, if you select "D" then follow the on-screen prompts, it will re-align itself equally between the two cars.
    RCO likes this.
