Self proclaimed expert explains why Prius Headgasket Failures are normal, early, and inevitable
Discussion in 'Gen 3 Prius Main Forum' started by Sal43, Oct 21, 2020.
  1. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Changing your coolants early and often and, getting full egr systems cleanings early and often and using a high quality oil catch can will only buy you a little extra time if what this guy is saying is true.
    The real reason for Prius Headgasket Failure is thermal expansion and contraction of the head and block towards and away from each other according to this guy.
    This happened dozens of even hundreds of times more often in a hybrid than a normal car.
    douglasjre and m.wynn like this.
    52,848
    i've heard of this before. it's usually because the designer did not pass material engineering class.
    since the gen2 wasn't a problem, and many gen3's don't have a problem, i have to wonder about inevitability...
    that being said, these guys know there stuff, and i don't.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Total BS.
    The temperature variation isn't THAT much while the engine is OFF.
    In a conventional hybrid, the engine really is ON most of the time.
    Like most self proclaimed experts, he really isn't.
    The other stuff he advocates is really just a waste of time and money.
    Now he has had his 30 seconds of fame.
    djasonw likes this.
  4. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    if anyone knows math= 60 minutes in an hour....10 hour "uber" comes to 500-600 times
    So if MY math is correct, the guy is saying a prius uber/taxi is starting and stopping and engine is
    cooling down every minute??? Or was I mistaken and two peeps taking shifts for total of 20 hrs/day
    so maybe every 2 minutes this happens :/facepalm...what was I thinking?
    Something tells me this guy is smoking something really good.
    djasonw, m.wynn and Mendel Leisk like this.
  5. Mendel Leisk
    42,343
    Yeah my money's on EGR clogging.
  6. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    I find that Torque shows the engine holds a pretty darn steady temperature once it is warmed up, even if it cycles on and off a lot. I DO believe that perhaps the original coating material on the metal head gasket was not totally compatible with the organic acid based coolant that Toyota uses. A reason I believe this is that I have yet to hear of a failure of a replacement head gasket (at all), and suspect we would be seeing it on this site by now if it were happening. I am sure that several DIY mechanics have done this job, many of us less than perfectly, and yet I still see no reports of a second failure once the original gasket is replaced.
    TheMainePrius likes this.
  7. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    The reason you see no reports is because a second failure (after the original gasket was replaced) would need ANOTHER 180,000 miles, or more. The average owner would not drive the car 360,000 miles in anticipation of another head gasket problem and the joy of reporting it. The car is wrecked, junked or sold well prior to those high miles. The "new owner" would have no knowledge of head gasket replacement. YMMV
    rjparker likes this.
  8. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    2ZR-FXE head gasket pandemic - pick a side and be a Richard about it.
    I'm still hunkered down as an EGR theorist, with a strong lean toward keeping the coolant and water pump/t-stat fresh, too:D:D:D
    djasonw, mjoo, mikey_t and 3 others like this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    m.wynn likes this.
  10. m.wynn
    684
    1,230
    Queensbury, NY
    no vaccine planned!
    Raytheeagle likes this.
  11. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Have only had one head gasket failure in fifty years..... 2013 prius v and the egr system was cleaned 60,000 miles ago.
    Plan on it going out.........plus inverter, brake system, plugged erg, traction battery, water pump and more.... these are expensive and Hard to replace...the water pump is the easiest.
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    My 2012v coolant temperature will cycle from 195f to 150f and back, especially when the system is in an extended "ready/idle" with the ac on. This is repeatable during long traffic delays and somewhat during long downhills. I think the Gasketmaster video above is a reasonable suggestion and, as he observes, similar engines in non-hybrids have less problems. There is little doubt improved designs and better materials in later models resolve the frequency of head gasket repairs.
    it is interesting that Gasketmasters can change head gaskets in your driveway for 1/2 to 1/3 of the dealer price. With a warranty. The dealer (and most of us) will usually suggest a new or used short block because of the oil burning issue, further discouraging the average consumer. Given that high priced dealer estimates on older cars drive new car sales, companies like Gasketmasters are a great value and service. As always experience is the best teacher. "Only He who has traveled the road knows where the holes are deep".
    #12 rjparker, Nov 22, 2020
  13. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I changed mine for $156.00 and a lot of cussing...... my two other toyotas running fine with hundreds of thousand more miles and never a head gasket problem
    car running exactly as is was before head gasket failure.....
    djasonw likes this.
  14. Mendel Leisk
    42,343
    The EGR passages in the intake manifold, the small ones at each port, tend to completely clog at cylinder one first. Cylinder one is also where the head gasket tends to fail.
    mizudu, douglasjre, djasonw and 3 others like this.
  15. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    When I did the egr I cleaned everything including all intake manifold passages....... with power washer and carb cleaner
    special attention applied to the small holes below each intake port
    and I have a Catch Can
    and I'm still running walmart 10W40 in the trani.
  16. Mendel Leisk
    42,343
    At what miles?
    Where I'm going: if the EGR cleanout is later, say well past 100k miles, maybe the damage is done.
  17. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    197,000
    It went an additional 65,000 after that till HG failure.
  18. Mendel Leisk
    42,343
    Yeah maybe too late, engine had been EGR starved too long, cylinder one the most/longest.
  19. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I have worried about that since the intake / egr service....
    If I would have known about this crappy HG stuff back then I might have changed it then.
  20. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Why does there have to be one smoking gun cause for head gasket failure? EGR issues and heat cycling could certainly both be contributing factors to the problem. With a better EGR system the heat cycling might not matter. With a better head gasket maybe the EGR doesn't matter as much. Everyone is just guessing.
