Self proclaimed expert explains why Prius Headgasket Failures are normal, early, and inevitable
Discussion in 'Gen 3 Prius Main Forum' started by Sal43, Oct 21, 2020.
  1. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    This thread makes me want to put KIRKLAND brand extra virgin olive oil mixed with canola oil in my engine the next time I change it. How can it be much different than Toyota 0w-20?
    gboss likes this.
  2. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    It will be better.
  3. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    It could clean the rings, one never know:D
    i actually had one of those wonders happen once. Had 20years old Corolla which had been running on mineral oils all her life. For some reason i put fully synthetic Mobil in and it started consuming oil. With mineral oil hardly any consumption. I just kept on driving and after second oil change the oil consumption stopped. I was really confused until a friend of mine told me ”your rings are now clean. you’re free now”:D:ROFLMAO: True story
    djasonw likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    I got some prime waterfront property in south Florida to sell you. For a really great price....
  5. Mendel Leisk
    42,343
    Yeah, my money's on Toyota 0W20. :)
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Diesels routinely run lean and not incur real mechanical problems. I've not heard of a diesel with an aluminum cylinder head. They also don't have throttles.
    Gasoline engines are more sensitive to lean conditions IMHO.
    moto g power ?
  7. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    GMs Duramax has had aluminum heads since it was introduced in 2001. The new 3.0l diesel for 2020 also has an aluminum block.
    V Sport Wagon likes this.
  8. Rocky Mountain Priusman
    224
    112
    If you dislike your prius so much and doubt its reliability, why dont you sell it for another vehicle you like more, and why are you spending time on a Prius chat forum? Or is it a love/hate relationship?
  9. OptimusPriustus
    338
    144
    Finland
    i think aluminum diesels are quite common nowadays. I’ve had at least two with such. One had went through head job at around 100kkm:) Bad lifters
  10. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Because I can......and I have 5 vehicles.
    I'm on here because of misinformed people like you.
    Why even reply to or post something from me.
    I know more about the 3rd Gen than you ever will.
  11. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Ecodiesel?
  12. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    Wow! Why the bitterness?
  13. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    One Gasket Masters video wouldn't tell the full prius head gasket story.
    Here's an older GM video showing what happens after driving long enough after the head gasket starts leaking
    youtu.be/8U1rs3bI-HA
    Finding the GM video where they replace a prius head gasket in the taxi yard somewhere around the bay area will give a few more clues as to what some of the possible causes of the Gen 3 head gasket issue is really about.
  14. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    :rolleyes:
  15. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I've never had glitter in any of the eCVTs that I have changed fluid from. Wonder why you get glitter?
  16. V Sport Wagon
    375
    131
    Southern California
    Because he's just such a ray of sunshine and positivity in all his posts, it's natural even his car would glimmer.
  17. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    No, as has become more clear relatively recently, it's more because the engineer who set up the water pump control programming forgot part of what he should've learned in Heat Transfer class.
    mikey_t likes this.
  18. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    Thermal cycling contributes which is demonstrable (40-50f after initial warmup) and is what GM said in the video. However carbon buildup from oil consumption and a bad pcv and egr design are also factors.
    Any engine can blow a head gasket if frequently overheated.
    Thermal cycling is not a factor in similar Corolla engines but the other factors remain. Corollas don’t have anything close to the problem.
    mikey_t likes this.
  19. Mendel Leisk
    42,343
    Strike out that bit and I'll go along with you.
    Mr. F and CR94 like this.
  20. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    would my logic be wrong that a non v with the V cooling which has been enlarged to hold more coolant effectively keep the motor cooler by having additional fluid circulating?
