self propulsion at idle
Discussion in 'Prius v Technical Discussion' started by jonb505, Dec 12, 2012.
  1. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Hard to put a subject title to this so I'll do my best to describe it. Perhaps I'll mention it at my next service if I can get some clarification from others who have experienced it.
    I've noticed it happen a few times in the 15000km of driving my v.
    I first thought it was unique to a cold start but last time it happened was after 30 minutes of driving on the highway, then stopping in traffic. Happens with the ICE running or not.
    So normally when coasting to a stop with foot off the pedals, the HSI shows 1 pip on the charge bar.
    With foot off the pedals in rush hour traffic at very low speed the HSI normally shows zero charge and zero power, no pips, idle position, right?
    So what I've noticed happens sometimes, while moving at very low speeds, in a lineup of cars moving along slowly with occasional stops, when I lift off the brake the HSI shows 1 pip above idle, no foot on the gas pedal and the car moves along on its own with only having to feather the brake to control speed(I'm not talking an out of control runaway prius, more like walking pace and only on a completely flat surface). It actually functions well in stop and go heavy traffic situations where it has happened as i don't need to be constantly shifting back and forth brake/gas brake/gas to move ahead a few feet in line.
    Normally on most occasions such as waiting in a drivethru lineup after sitting for a few seconds, on releasing the brake pedal I usually have to push on the gas pedal to move the car at all, it will just sit and not move on a flat surface with no foot on the gas or brake. Come to think of it self acceleration from idle seems rather random, sometimes the car will roll along on its own, other times it will roll back a bit if on a bit of a hill, good thing for the hill start assist!
    So I'm wondering, is this a feature or does the HSD just get confused sometimes causing idle position to be slightly different under varying temperatures and driving conditions? Extreme cold could be a factor, as far as I can remember, it has usually been very cold whenever this strange idle behavior has happened. Perhaps it is just the nature of the HSD, at times it almost feels like a living thing with a mind of its own. :confused:
    52,739
    :)mine always 'creeps' when my foot is off the gas and brake, just like a standard automatic transmission. i would be more concerned about when it doesn't creep. unless you are on an uphill grade.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    same here, both Prius I have owned creeped forward when all pedals are empty.
    Actually, every car I ever owned, manual or automatic, moved forward when all pedals are empty.
  4. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Ah, yes that's the word I was looking for, "creep". That one word may have saved everyone who came in here from having to read my long winded original post. :)
    Basically I noticed the amount of "creep" is not always perfectly consistent. Sometimes it feels like the cold start "high idle" effect you would get in a non-hybrid automobile where you would get an extra boost of "creep power" till the engine settled down.
    Perhaps the Prius tries to "simulate" the high idle effect as it does other drive-train features from normal cars such as engine drag while coasting.
  5. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Just did a search for prius idle creep and found this thread among others: Disable Idle Creep! | PriusChat
    I guess this subject has already been discussed many times over, sorry for beating, yet again, the old dead horse. :D
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    fuzzy1 likes this.
  7. Air_Boss
    Air_Boss Senior Member
    4,241
    1,192
    New Yawk
    Manual? In gear, sure. Out of gear? Park on a level surface next time... or set the parking brake.
  8. bisco
    52,739
    amount of creep may be a bit variable on level surfaces depending on ice rpm's or ice off. if you ever find zero creep on a level surface, you should have it checked.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The creep is always there by design. Watch out for optical illusions. There is an exit off Hwy 805 in San Diego. You exit the freeway and stop at the light. You can see the street rising up in front of you. So it appears you are on a steep hill looking down. However, if you let go of the breaks, you will not creep and actually fall backwards seemingly uphill. My wife tells me a school bus full of children once took this exit too fast and careened off the cliff ahead. Falling backwards is because the ghosts of the children are pulling you back up to safety.
    List of gravity hills - Wikipedia, the free encyclopedia
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I had a manual transmission Datsun that would creep in neutral, when the temp was -10 °F or less.
  11. Air_Boss
    4,241
    1,192
    New Yawk
    Needed a clutch adjustment...
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Nope. It only crept with clutch engaged. 80W-90 gear oil offers enough viscous friction to do this.
  13. Air_Boss
    4,241
    1,192
    New Yawk
    Only if the gear oil was on an engaged clutch plate/flywheel interface.
    Gear oil in the transmission (cold, or at operating temps) is disconnected from engine torque when the car is out of gear.
  14. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    Or it's just quirky behavioir on an ancient vehicle :)
  15. Air_Boss
    4,241
    1,192
    New Yawk
    Just speaking from experience with my 45 year old... and others of that vintage.
