Self Tapping Oil Plug
Discussion in 'Gen 3 Prius Technical Discussion' started by Taxi/Limo, Sep 15, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    A freind of mine suggested a "Chaser" to fix the problem
    Is that the same as a thread chasing tap?
    If so what about little pieces of metal ?
    Thanks
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    Yes, but you gave to be sure. The term can be loosely used.
    Get this set off of eBay to be sure.
    Lang Metric Rethreading Tap Set Thread Restore 6pc 6-12mm Made in USA
    #22 Georgina Rudkus, Oct 7, 2022
  3. Taxi/Limo
    526
    107
    Not sure what you're saying
  4. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    Just saying that only close examination can deternime if a tap is either thread forming or thread cutting. Not all rr-threading iools are the same.
    Taxi/Limo likes this.
  5. Mendel Leisk
    42,314
    Just did the oil change a day back, torqued to the spec (27 ft/lb), and really starting to wonder about that number. Especially with oily threads. Probably will stick with it, but…
    appreciate this is off-topic, just on my mind. Better than an impact wrench I guess.
  6. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    I started using Nissan copper crush washers instead of the Toyota ones.
    20pcs Oil Drain Plug Gasket Washer Seal - 12mm Crush Washer Oil Drain Plug OEM 11026-JA00A Replacement for Nissan/Infiniti Fits Most Popular Models 1982-2022 by AUTOMAJOR
    There is exactly no way to know that the Toyota "crush" washer is fully "crushed."
    They actually "crush" when the drain plug is tightened. A quarter turn past fullu crushed "crushed" down appears to be the ideal tighness. Used them three times with absolutely no leaks.
    Other than that, the Viton "o" ring appears to be a good alternative, if the threads are messed up and do not hold well.
  7. Taxi/Limo
    526
    107
    How will I know ?
    Thanks
  8. Taxi/Limo
    526
    107
    I am getting a magnetic oil plug to use after to use after we do a chase
    Would it be advisable to flush the oil pan with some cheap oil to make sure any metal shavings come out ?
    Or
    Would a magnetic oil plug be sufficient?
    Thanks
  9. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    The magnetic plug should be sufficient. Thread chasing as opposed to cutting produces very little swarf or cuttings.
    #29 Georgina Rudkus, Oct 8, 2022
  10. Taxi/Limo
    526
    107
    Are there any videos or instructions on how to do a thread chaser?
  11. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    When I had a leaky oil plug in a Prius C it was bad threads and was planning to replace the whole oil pan, but the largest thread chaser in the $18 Harbor Freight Tap & Die kit I have was same size and I had oil slowly dripping out to prevent metal shavings from getting in there and slowly spun it around with it attached to some vise grips to clean up the threads. Problem solved!
    If that doesn't solve it you'll have to rethread one size larger with larger drain bolt. Alternatively, Toyota oil pans are the same for all 4 cylinder engines and cost less than $30 online.
  12. Mendel Leisk
    42,314
    Aftermarket, Dorman or the like? Searching for Toyota part:
    Foothills Toyota is the $94~ USD, a nearby, just across the border option for me.
    https://parts.foothillstoyota.com/p/Toyota_2010_Prius-Hatchback/Engine-Oil-Pan/62915385/1210237010.html?referer=parts.toyota.com&machineIDT1=fztluczatvmfnkkly0zhsvbh
    Searching the same part no, a Canadian site is $178~ CDN
    https://www.toyotapartsdirect.ca/p/Toyota__Matrix/Engine-Oil-Pan-Lower/49525153/1210237010.html
  13. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    Clean Chase and or re-tap no matter if you get some stuff in the pan and it's really bothering you all you need is your shop vac set up for liquid pickup drop a little kerosene or some lightweight type oil in the pan through the oil fill hole maybe just a little less than a quart to wet the pan now take your shop vac computer cleaning kit which has like a little hose and a little angle fitting that will fit right through the drain plug opening and allow you to suck up the kerosene and the shavings right into your shop vac takes a second You could also just continue pouring the kerosene through the oil fill hole with the tap toe ready to go and watch the shavings and the kerosene run into a mayonnaise or a mason jar then add a little bit of oil as it's heavier and it might pick up one or two more shavings then put the plug in and continue to fill with oil and get on with your life more than likely shavings of minute size are always in your oil from the time you pick up your car brand new at the dealer and start driving it all the way up through 100,000 miles or so granted they're generally not large enough to cause any problems but you see the point.
  14. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    You just screw in the tap like you would the drain plug.
    But you start the tap a few turns, then back it out a half a turn, then a full turn,
    back out a half turn, etc.
    You can put grease in the grooves of the tap to catch the cut threads.
    Tombukt2 likes this.
  15. PriusCamper
    13,440
    5,426
    Lol... You probably spend alot more money on parts than you have to... Ebay and Amazon have plenty of them for under $30: https://www.ebay.com/itm/321647375093
    Mendel Leisk and Tombukt2 like this.
  16. Mendel Leisk
    42,314
    Why such a disparity though. Could it be parts department employees selling them on the sly?
  17. PriusCamper
    13,440
    5,426
    Nope... It's alot like price drop in cat shields because most machine shops can make those with one tool. Similarly, a machine shop can buy an oil pan mold for a common Toyota engine and put a couple sheets of metal on it and press it and sell it and make easy money.
