Selling soon
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan05979, Jul 30, 2019.
  1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    After 4 years of good service it's time to let my gen 3 go. Car has been good but this last 6 months the engine is giving me trouble. Engine rattle, burning oil is the main ones. I put on at least 130K miles in the 4 years I've owned her but I replaced it with a 2018 camry XLE 26K miles. lets see how this camry performs.
    Good times when I got the windows tinted
    Replacement vehicle with my Accord
    mikey_t, RMB, Tideland Prius and 3 others like this.
    52,863
    congrats, all the best!(y)
    Dan05979 likes this.
  3. Dan05979
    Dan05979 Member
    181
    101
    Thanks hoping for the best
  4. ETC(SS)
    7,569
    Best Wishes!!
    Be sure and stop by every now and again to keep in touch!
    Best of luck with the Camry.
    Let us know what you think of the new Camry!
  5. Dan05979
    Dan05979 Member
    181
    101
    So I did everything possible to get my prius running correctly, changed egr valve, cooler, intake manifold, throttle body, camshaft position sensor, ignition coils, spark plugs but the engine is still running horrible. So I took it to a mechanic and had him look it over and he told me it might be a rod bearing. so the engine is pretty much junk. So now I have to search for a used engine and pay the labor. This is very upsetting since i took very good care of my prius and had no leaks of any kind. Sad day.
    Mendel Leisk and bisco like this.
  6. JC91006
    16,936
    8,647
    Does it misfire? Can you test for a bad head gasket?
  7. Dan05979
    Dan05979 Member
    181
    101
    it's having random misfires on every cylinder. as far as head gasket I have no coolant leaks and when I removed all the spark plugs they were dry.
  8. bisco
    52,863
    how many miles on her? how much oil per 1,000 miles? how is the compression?
  9. JC91006
    16,936
    8,647
    I would check your fuel injectors. Or maybe outright change them out
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What was your choice of engine oil & filter?
  11. Dan05979
    Dan05979 Member
    181
    101
    Dealer oil changes, and when I had to add oil I kept a 5 gallon jug of Liqui Moly
    Grit likes this.
  12. Dan05979
    Dan05979 Member
    181
    101
    184K, I added oil every 2K miles about a quart, don't know the compression.
  13. bisco
    52,863
    that's not horrible, i think the max spec is 1 qt/600 mi
  14. mpg_numbers_guy
    116
    64
    VA
    Are you planning on replacing the engine yourself? At 184k miles the cost of replacing the engine might come close to, if not exceed the potential selling price of the car.
