Sense lead wire has come off help
Discussion in 'Gen 2 Prius Audio and Electronics' started by TonyPriusuk08, Jan 17, 2017.
  1. ChapmanF
    19,027
    The most direct way to find what part to buy is to sign in to toyota-tech.eu and pull up the Electrical Wiring Diagram for your car, click that circuit to highlight it, click the little orange Info icon in the lower right, which will show you a drawing of the connector ... click to expand the "Wire Harness Repair" link, and you will be shown the exact part number for the repair terminal (which is just like the terminal you have, but with a short length of wire attached, which you splice to your original wire).
    -Chap
  2. Reeftech
    Reeftech New Member
    Suva Fiji
    2011 Prius Alpha
    Hi
    could you tell me the function of LEAD SENSE wire and the circuit diagram photo if you have any would be a great help.
    Thank you in advance
  3. Arthur Munoz
    Arthur Munoz New Member
    Huntington park
    For this problem what codes come up on your scanner
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    This is an easy repair, as pointed out to you but someone here. Y not just attempt any of those, first?! You just want to spend some £ by all means?
  5. ChapmanF
    19,027
    All the posts here are five years old, except for #22 (what does it do?) and #23 (what trouble code do you get if it doesn't?).
    So the answers to those are: what it does is allow the DC/DC converter under the hood to control its output voltage so that it is correct at the battery in the back of the car.
    When it doesn't, you get one of the converter codes, I think P0A08 (do not confuse with P0A80, a battery code) ... maybe P0A94.
    There is also a 5 amp fuse next to that sense lead, which sometimes gets blown in reverse-jump accidents. That will also give the same converter code. Sometimes a repair shop will see that code and think your inverter/converter got blown and they have to replace it.
    James Analytic, maleko and dolj like this.
