Sequence at power on, Prius V not going to ready only shifts to neutral
Discussion in 'Prius v Main Forum' started by ZeroM8, Oct 10, 2023.
  1. ChapmanF
    18,241
    So we know the ignition 3 fuse isn't the one.
  2. ZeroM8
    ZeroM8 Junior Member
    74
    Toronto
    2001 Prius
    Update:
    Finally got it working, after we fixed inverter connection, we tried boosting up again. Funny thing is that when the battery is very low, the battery has a lot of current draw. In my mind there must a a relay that's powering up a motor somewhere, not a safe design in my opinion. Didn't had time to find out where it's coming from. It got me very worried at some point thinking there's a short somewhere.
    I don't think it's a problem with my car since at 11-12V, the whining sound coming from the engine bay disappears. I observed it last night after parking and with the 12V battery charged, and again this morning and it is quiet. Could it be also the hybrid battery powering up one of the motors? Questions, questions... Could the 12v relay that powers up the interlock on the hybrid battery gets stuck at a very low 12v battery?
    I took it for a drive with the dash lit like Christmas tree, since my scanner showed no issues with the Hybrid system, after the inverter connection fix.
    The crankshaft and camshaft P0335 and P0343, the mass airflow sensor low and air intake temp high, P0102, P0113 stayed on until I drove for about 5mins.
    An error B2313, electric window, passenger door, I was able to clear this morning following the procedure in one of the posts here, which was to do some form of calibration for the drive motor, i. e. hold the passenger side button for a couple of seconds after it reaches the ends.
    The last lingering error about the speed sensor on the wheel hub but i forgot the code, I'll pull it out again at some point and post it here.
    Was just relieved the transmission is good, as that was the bulk of the work and I couldn't imagine if it was bad that we have to do the work all over again or scrap the car
    Thanks for the responses, it certainly helps to get information here when one gets stuck with issues.
    Air_Boss likes this.
  3. ZeroM8
    74
    Toronto
    2001 Prius
    These are the pictures of my transmission and clutch/damper disk before we changed them. Both are broken.
  4. ChapmanF
    18,241
    so broken i can't see them at all
  5. ZeroM8
    74
    Toronto
    2001 Prius
    How can I upload images now? I tried upload a file button and it went through but where does it go huh?
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,162
    6,316
    Texas Hill Country
    Good ol’ sluggish Priuschat needs weight loss surgery. Wait 15 seconds after doing the file upload before saving. Even then it will often look like it did not save, encouraging a second or third try.
  7. ChapmanF
    18,241
    JavaScript turned on? I've never succeeded with an image upload without it.
  8. ZeroM8
    74
    Toronto
    2001 Prius
    Second try, used to be easier before to upload images...
    Springs been broken since 2018 making rattling sound when driven (daily)
    It finally gave up tho not too quickly
    I suppose the motors MG1 an MG2 still good? Never opened the assembly to find out
  9. ZeroM8
    74
    Toronto
    2001 Prius
  10. ZeroM8
    74
    Toronto
    2001 Prius
    I'm using my phone but it's working now
  11. ChapmanF
    18,241
    ooh, crunch.
  12. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    Crunchy…
