Sequence for entering Maintenance Mode not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brad from Ohio, Nov 2, 2021.
  1. Brad from Ohio
    Brad from Ohio Junior Member
    17
    Cleveland
    What do you do when you can't get your Gen 3 into Maintenance Mode?
    Followed the sequence shown here:
    1. Begin with the car and all accessories turned off.
    2. Set the parking brake.
    3. With the car in Park, and your foot off the brake pedal, turn the Power Switch "On" by pressing it twice.
    4. With the car in Park, and your foot off the brake pedal, fully depress the accelerator twice.
    5. Step on the brake pedal and use the shift lever to shift from Park to Neutral.
    It won't let me shift it into Neutral.
    It doesn't respond to the joystick(shifter) after performing steps 1-4. Thus am getting stuck at step 5.
    Please advise, is there another way to get into Maintenance Mode?
    Disconnected the 12V auxiliary battery and reconnected it reset the ECU, but that didn't correct the issue.
    Not showing any Error codes in the Torque or Dr. Prius apps.
  2. ChapmanF
    19,061
    Are you holding the shifter at N for the needed amount of time? There's a delay, just like shifting to N any other time.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,148
    6,988
    Texas Hill Country
    Works for me, take your time
    Maintenance Mode to Continuously Idle
    1. Press 2 times start button
    2. Press 2 times gas pedal
    3. Hold brake petal shift P to N
    4. Press 2 times gas pedal
    5. Hold brake petal shift N to P
    6. Press 2 times gas pedal again
    7. Hold brake pedal and start engine...shut off to return to normal
    burrito likes this.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,258
    953
    tweedle99 likes this.
  5. Brad from Ohio
    17
    Cleveland
    Yes Azusa, tried putting into Maintenance Mode from the Dr. Prius app, but nothing happened.
    Figured out the issue. The culprit turned out to be a failing 12V battery.
    Only needed to get into MM to properly bleed the air out of the system after adding some radiator fluid.
    Upon attempting to get the car into Maintainance Mode,couldn't. And worse yet, all of a sudden had to push Power a few times to just get the car to start.
    Couldn't figure out why attempting to enter MM would impact the ability to start.
    Wasn't evident at the time of the post. As the battery was less than 4 yrs old, had ruled it out. Jumped to assume the vehicle computer was jacked up like an old Windows XP computer OS.
    After reading other forums learned that what was occuring was that the engine was being started via the hybrid battery and rather than from the auxillary battery. Upon replacing the 12V battery it now consistently starts right away and all systems are working proper.
    FYI - the AGM replacement battery with tax was $212. That's nearly double of what it costs 4 years ago - crazy inflation/gouging occuring!
  6. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    Double?? What the h*ck is going on
  7. ChapmanF
    19,061
    I replaced my Gen 1's aux battery something like five years ago, and my Gen 3's a year or so ago, and a family member's Gen 2 something like three years ago, and it was around two hundred and change each time.
  8. OptimusPriustus
    338
    144
    Finland
    Just checked some Exide 95Ah AGM battery prices around here. They appear same they’ve been during the past 5-6 years. I’ve bough three of them during this time frame so i remember well
  9. Mendel Leisk
    42,381
    Local, west coast dealership parts dept quoted me $340 CDN a few weeks back, for the Yuasa. Battery retailer in Saskatchewan will sell me the same battery for $230 CDN, ship to me battery for free, and the sales tax will be (roughly) 6% (vs 12% locally). The Saskatchewan battery likely passed through the port of Vancouver, on it's way east.
  10. Kmun
    Kmun Junior Member
    Oregon
    Maintenance Mode
    1) In Park & Foot Off the brake
    a) Press Power Button 2X​
    2) Depress & HOLD foot on the brake pedal
    a) Fully depress gas pedal 2X (in Park)​
    b) Shift to Neutral​
    i) Depress gas pedal 2X​
    c) Shift into Park (Park button)​
    i) Press 2 times gas pedal (while in Park)​
    d) Power button 1X to start engine, orange dash light illuminates.​
    3) Release foot off of Brake
    4) Run tests while engine running
    5) Depress Power Button to return to "Off"
