Seraching part Panel Sub-Assy - 55405-47030-B0
Discussion in 'Generation 1 Prius Discussion' started by Tilmann Ströhle, Dec 15, 2025.
  1. Tilmann Ströhle
    Tilmann Ströhle New Member
    Germany
    2000 Prius
    I
    mine is broken. So I am looking for this part:
    CONTROL ASSY, CENTER CLUSTER MODULE
    I am not able to find this part in Germany. There are only 120 cars let here...
    Maybe someone has a used one in good condition?
    Thanks!
    #1 Tilmann Ströhle, Dec 15, 2025
  2. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    When you could find them here in America they were $200 or more. Time to get creative my friend.
  3. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Yeah I wish you well on that every one of these I see at least screen is toast and the plastic pictures here has taken on damages .
  4. Jakob
    Jakob Junior Member
    69
    Wisconsin
    2003 Prius
    Agree, get creative. And if it's just cracked or you have all the pieces that means welding it back together. I have on my to-do list to pull off my own cracked panel and do this repair. I recently bought the "Touch-N-Flow System" for a different plastic welding project, and as far as I can tell it worked well. The applicator allows you to precisely apply solvent along a crack, with capillary action pulling it in for a complete joint. If the panel is ABS then the "Plast-I-Weld" solvent in that kit is appropriate. I assume there's a plastic code stamped on the back of the part somewhere, but I didn't check when I had it off before.
    So get applicator and correct solvent, prop/tape parts together as needed so they're flush and won't move (and ideally under a bit of compression), and apply the solvent according to instructions.
  5. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    if you are taking that panel off you will be doing some major repairs. Each place where it clips/presses into the metal dash will break and likely both ears/vents will break off as well. When I said “get creative” I meant use some duct tape then leave I alone!
  6. Jakob
    Jakob Junior Member
    69
    Wisconsin
    2003 Prius
    Yeah, I'm hoping consulting this video might help prevent further damage when I try again to remove it. It also shows that the piece is made of a polycarbonate-ABS blend.
  7. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    I think you have to come at it from the engine compartment to keep it from breaking.
  8. ronlewis
    1,059
    205
    texas
    2001 Prius
    If you get bored seraching, this could spice things up.
  9. DavidDM
    DavidDM Junior Member
    Houston
    2001 Prius
  10. Trombone
    Trombone Active Member
    378
    129
    Allentown, Pennsylvania
    2002 Prius
    The one-and-only original! My Fave! Great on poached and over-light eggs! Also good in tomato soup and New England clam chowder.
    Good call!
