Serious & Catastrophic Safety Problems. Help, Stranded!
Discussion in 'Gen 2 Prius Main Forum' started by 2005ToyotaPrius, Dec 5, 2011.
  1. YES, Cruise Control.
    1 vote(s)
    2.3%
  2. YES, Steering.
    1 vote(s)
    2.3%
  3. No.
    42 vote(s)
    95.5%
  1. 2005ToyotaPrius
    2005ToyotaPrius New Member
    West Lafayette, IN
    Like many of you, I have been a Prius devotee, and when I embarked on a long-distance trip, my 2005 Toyota Prius gave me confidence. Sadly, my confidence is gone after experiencing back-to-back serious, then catastrophic, safety problems that could have easily left me, and others, dead or seriously injured. Fortunately, I have merely been left stranded, in Jacksonville, FL, happy to be alive but not knowing what to do next. I'd like your advice. Here's what happened:
    I was driving on the Interstate with the cruise control set at 70 mph. Seeing traffic stopped ahead, I applied the brakes for a moment to slow, then released the brake to coast. Much to my surprise, the cruise control was still engaged and the car accelerated. I applied the brakes again, manually turned off the cruise control, then was able to coast. I drove for another half-hour without incident until the following afternoon when I drove again, experiencing a much more serious problem.
    I had just turned left, and was straightening the wheels when I heard, and felt, a loud "snap" in the steering wheel, immediately upon which I knew the steering wheel was disconnected and I could no longer steer the car. Very, very fortunately, and only because I was already nearly stopped, I was able to stop the vehicle without incident. However, I immediately recognized that, had this happened in almost any other scenario than being nearly parked, the outcome would have been markedly different. The steering wheel is completely loose, not controlling anything, and all the many steering wheel controls are equally disconnected, including the driver's air bag (SRS), something that I would have needed, but wouldn't have worked, had I crashed into oncoming traffic or an Interstate median. Had I not decided to run a frivolous and unnecessary errand, I would have otherwise been on the Interstate, rushing home for Thanksgiving like many others, but now am merely stranded, in a motel, far from home in Jacksonville, FL, wondering what to do next.
    My low mileage (just 27,773 mi), seven year old Prius is still parked, undriveable, exactly where she died. I called a tow truck, and Enterprise car rental, right afterwards, but neither showed ... it was Thanksgiving Eve. I ate cold, leftover pizza for Thanksgiving, but was otherwise happy to be alive and have a roof overhead and thinking that the two no-shows may have been blessings in disguise. Having had unsatisfactory resolution of some relatively minor problems when this car was new (cruise control wouldn't resume, poor radio reception, steering that seemed to take me out of my lane, and bad, Goodyear Integrity tires that I ended up replacing myself), and questionable, rip-off maintenance since, leaves me questioning whether or not I can trust Toyota to do right by me, particularly given how serious this situation is (and easily could have been, if not for me, for others) and what circumstance I now find myself in. I want to ensure this is handled correctly so no one else will ever encounter what I have faced but with an easily, potentially much more catastrophic outcome.
    Do I trust Toyota to do right by me and repair THEIR problem? Do I pay Toyota to repair THEIR problem, covering-up the inherent issue and leaving me with a car I no longer trust? Do I shell out the big bucks to buy a new vehicle, a financial burden I can't afford right now? Do I repair it, then trade it in on a new vehicle, or trade in an undrivable car, getting very little of the value it has to me? These, and many others, are questions I'm considering. Your help would be most appreciated!
    Thank you!
    Sincerely,
    George
    Service-connected / Disabled (unemployable) Veteran
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there's a recall for the steering wheel. it applied to certain 04 and 05's.. if i recall correctly. the steering shaft can snap causing loss of control. sound like your problem.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Sounds like you had a bad dealer and should've taken it elsewhere. I've never encountered "questionable, rip-off maintenance" w/my Prius that's almost 6 years old with >59K miles now.
    Assuming everything you're reporting is legitimate, I would absolutely file a safety complaint at https://www-odi.nhtsa.dot.gov/ivoq/index.cfm.
    Regarding steering, yes, you should be able to see the recall info at Recalls - Search Results | Safercar.gov | NHTSA. Perhaps you never had the recall work done?
  4. 2005ToyotaPrius
    West Lafayette, IN
    Thank you for the recall information! Toyota notified me about the floor mat recall but no others. Thanks, again!
  5. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    You can find out more about the recalls via Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
    If you register aat Toyota Owners Official Website: Service Coupons, Owners Manuals, Service Scheduling and More, you should be able to view your dealer service history and it might show any outstanding recalls.
    If your car has the steering shaft recall outstanding and you had taken it a Toyota dealer for maintenance after the recall notices went out, then that dealer was negligent for not informing you and offering to do it. That would be yet another reason to no longer go to that dealer for service.
  6. Tideland Prius
    16,664
    Our 2005 has had the steering wheel recall done. I'm sorry to hear of your two situations.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The steering recall came out a long time ago. I had it done shortly after purchasing my 2005. It's too bad your dealer didn't inform you of it. Someone could have been hurt. :(
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    George, that sounds like a really tough situation. Have it towed to the nearest Toyota dealership. Make it very clear that the clockspring is broken as well as the intermediate shaft -- this is the cable that connects the steering wheel controls and airbag to the rest of the car. It should be a free tow and repair. You might want to start with the Customer Experience line at 1-800-331-4331.
    Here is some more info:
    May 31, 2006
    WASHINGTON – Toyota Motor Corp. said Tuesday it is recalling nearly 1 million vehicles across the globe to replace faulty parts that could cause drivers to lose control of the steering wheel.
    The recall affects about 986,000 vehicles across 10 models, including its popular Prius hybrid car. More than half of the affected vehicles are in Japan, company officials said.
    The intermediate shafts and sliding yokes in the recalled cars lack the necessary strength and could distort or crack under strong pressure, causing drivers to lose control of the steering wheel, the Japanese automaker said in a statement.
    In the United States, Toyota is recalling about 170,000 Prius models because the steering shaft assembly could become loose or crack under certain conditions.
    Toyota said there have been no reported crashes or injuries connected to the problem in the United States. Owners are expected to be notified of the recall in mid-June.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I believe there was a 2nd Service Campaign regarding the brake switch specifically addressing a cruise control situation you've mentioned. I had the opposite effect where a dirty signal from the switch triggered a check-engine light and disabled cruise control entirely. This came right when the campaign was launched, but again, this was VERY early in the vehicle service life (Late 2004, early 2005ish maybe).
    2 people like this.
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yes, the two faults are unrelated. The first to occur is just that the brake switch isn't adjusted correctly. If you had applied the brakes harder it probably would have shut off the cruise. Note that, in the Prius, the brakes are MUCH stronger than the HSD (drive system). So even if you had a catastrophic failure of the cruise, locking it on (which you didn't) you could have stopped easily. DO have the switch adjusted, as it applies the brake lights, warning drivers behind you are slowing.
    DO call the 1-800 number listed above. Toyota will have the vehicle towed to a nearby dealer to have the steering shaft repaired along with the cable the shaft severed. It -should- still be done on warranty, even though your car is out of warranty. It's their (dealers and Toyota) fault you were not notified of the recall.
    While Toyota -should- have caught your vehicles problems earlier the final responsibility does belong to the vehicle owner to keep it properly maintained. So you do bear -some- of the blame. Not being a mechanic or privy to Toyota's recalls (unless you were notified and ignored it or it went to the wrong address) you can't be blamed much for these faults, however.
    A tip, for brake light care. In a -very- dark place you can see when the brake lights go on because you can see the "high centre lamp" come on in the rear view mirror, especially when the rear lower glass is dirty.
    2 people like this.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The biggest problem you have is you've lost confidence in the vehicle and don't have confidence in the dealership.
    I wouldn't trade it in or sell it. You don't believe it now, but anything broken can be fixed. And The Prius can be a reliable and safe automobile.
    If you've irrevocabely lost confidence in your dealer, try another. But personally with less than 30,000 miles on your vehicle? I'd just have everything fixed and hopefully you can slowly regain confidence in the vehicle again.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    In a situation like this, it's important to recall that the dealer is not Toyota. In this country, dealerships cannot be owned by the manufacturer. Some dealerships are better than others.
    If you have had service at your dealership and they didn't inform you about the recall, then you have a real complaint. If so, you should contact Toyota and explain the situation. At the very least, you may force some improvement of your local dealership.
    Tom
  13. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    I am assuming that you bought this car as "previously owned" (used). If you bought it from a Toyota dealer they should have run the VIN prior to you picking up the car and they would have known that the steering shaft had not been replace. The other possibility is this car was never serviced by a Toyota dealer because this TSB is quite old. So don't be too despondent it is not the cars fault this should have been fixed way before you owned the car.
  14. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    I would, additionally, present Toyota (not the local Dealer wherever you are) with a bill for the room and any meals and incidental expenses while you wait for the repair. Maybe they'll pay it, maybe they won't, but you can't win if you don't play. Also, as a fellow American, THANK YOU for your Service!
  15. oldasdust
    oldasdust Member
    356
    47
    illinois
    Can You say Ayrton Senna
  16. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    I can, indeed. Have to imagine it focuses a man's attention when he finds himself entering a hard left hand turn at high speed and the steering wheel detaches in his hands.
  17. Mickduc
    Mickduc Junior Member
    47
    Oak Park, IL
    Was the steering shaft a recall? Unless a recall was issued an item in a TSB may never get written up if you go to a dealer. Unless the dealer has their computer system set up to flag all TSBs and the service writer writes it up you will never get the work done. If TSB items are left up to individual techs to add then there is even more room for it getting overlooked. Recalls are required, general TSB recommendations are not.
    Mick
  18. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  19. 2005ToyotaPrius
    West Lafayette, IN
    Just a quick note to thank everyone who has responded so quickly and considerately! I appreciate everyone's thoughtfulness!
  20. 2005ToyotaPrius
    West Lafayette, IN
    Once again, I want to thank EVERYONE for their post(s)! Guamkelly's thank you is most appreciated! Oldasdust's reference to Ayrton Senna is pretty sophisticated (I had to look that one up). That everyone took the time to write with pertinent, valuable, thoughtful information impresses me deeply! THANK YOU, THANK YOU, THANK YOU!
    Cheers!
    George
