Serious concern haunts me
Discussion in 'Gen 2 Prius Main Forum' started by rjmiz, Jan 18, 2007.
  1. hill
    9,040
    <div class='quotetop'>QUOTE(ewhanley @ Jan 19 2007, 12:44 AM) [snapback]377593[/snapback]</div>
    Yes, we Montanans use studs for many months of the year, but more states than not make them ILLEGAL. Back to snow tires for NY.
  2. Jack Kelly
    Jack Kelly New Member
    1,434
    I, too, was from upstate NY (Utica/Poland). A lot depends on the composition of your mud. There's gravelly mud, for which there's hope using the back-up-and-go-vroom method. Then there's Pure Dirt Soup, for which there's no answer short of a Farmall tractor.
    It might be surprisingly less expensive to run a couple of loops of heating coil under the edges of your driveway than you think.
  3. johnnymg
    johnnymg New Member
    <div class='quotetop'>QUOTE(Miz @ Jan 18 2007, 06:29 PM) [snapback]377543[/snapback]</div>
    Miz
    That really does suck! In all my net research this issue seems to be one that pops up as a REAL safety issue. :( . Hopefully Toyota will "fix" this problem in the next model. In the mean time............... sounds like mud/snow tires are the only solution for the current version.
    Regards
    JohnG
  4. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    Tires aren't the solution when TC bogs the car down on a gravel driveway in the middle of the summer.
    It's a serious design flaw and as others have said, Toyota needs to address the problem.
    I bought this situation up during a previous life on Pruischat and got the the same "mine is bigger than yours" crap as I'm reading now. Some things never change.
    Don't bother to suggest that If I don't like it I can leave. I've already figured that out for myself.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    The Prius was never designed for "off roading". If the driveway is gravel and becomes mud when it rains or snows, maybe the answer is to pave the driveway.
  6. rjmiz
    rjmiz New Member
    <div class='quotetop'>QUOTE(Godiva @ Jan 20 2007, 10:42 PM) [snapback]378500[/snapback]</div>
    Whoa wait a minute....your possible suggested solution to pave a driveway is NOT at all a reasonable one. It
    is not asking too much for a $26,000 car to make it up a gravel driveway, where any other car would go. If
    given your suggestion as the only alternative, I would rather sell the Prius, and swap it for a car of comparable
    capabilities with the exception it make it up my driveway.
    Your totally out of line here. I would rather think I should read your solution with tongue in cheek.
  7. member
    member New Member
    197
    <div class='quotetop'>QUOTE(ewhanley @ Jan 18 2007, 09:44 PM) [snapback]377593[/snapback]</div>
    If this is true, it must have been extremely dry powdery snow like we often see in Colorado. There is no way a Prius with stock tires is going to plow through 10" of snow with 5" of clearance in wet snow. I have great snow tires on and could not do that.
