serious drop in MPG. 20-22 MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by bret kraupie, Feb 6, 2021.
  1. bret kraupie
    bret kraupie New Member
    My 2011 when bought was getting ave. mpg 50+-. Moved from Seattle to San Diego and ave. 60-62 mpg going down. Coming back only got low to mid 40's. Its been a year since but it has slowing dropped to the mid 30's. and last week I noticed only 21-23 mpg. Yikes. I have noticed when I start driving while car is cold the mpg indicator does not jump up to 100 plus like normal. is stay 20-50 and after I drive for a bit it works correctly. I have 120,000k on car. I'm going to fill up and manually and see
    what my mileage is on next fill-up. Also was going to change spark plugs. Any other info. Thanks.....
  2. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
    bret kraupie, mikey_t and kenoarto like this.
    52,803
    welcome!
    clean the egr circuit before you blow a gasket, if you haven't already
    with 120k, i would do a major service as well
  4. bret kraupie
    I tried top find my battery reciept
    Ya Ill check it out. I put a new one in the car about three years ago, but maybe it is failing. I put new spark plugs in yesterday. It seems to be better(not totally). Thanks
  5. bret kraupie
    I checked the battery out and it is fine....
    can you tell me what egr stands for thanks.
    #5 bret kraupie, Mar 2, 2021
  6. bret kraupie
    Ya the battery is fine..
    #6 bret kraupie, Mar 2, 2021
  7. bret kraupie
    Thanks. Ill check the EGR. Are you talking about the tube that goes to the manifold. and I assume check both the ends that the tube hooks to.
  8. bisco
    52,803
    bret kraupie likes this.
  9. fuzzy1
    10,690
    What is the typical trip length now? If under 2 miles, that might be reasonable. But if much longer, then not so good.
    The EGR cooler, a heat exchanger that is plumbed into the engine cooling system, is a particularly bad clog point.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    what type of meter did you use that displayed “fine” in metric units?
  11. bret kraupie
    Not sure. I had Napa auto parts, and O rileys auto parts checked for me. They both said it was good.
  12. Mendel Leisk
    42,296
    Exhaust Gas Recirculation. More info:
    Bad Flywheel | PriusChat
  13. Rick2015Prius
    Rick2015Prius Junior Member
    Berkeley
    Hmmm, how did you come out?
    I have a 2015 that is all of a sudden getting 20. It has 116k and has been sitting a lot this past year. I also recently took it to Toyota for a software recall update but not sure that is the issue.
    It is ready for a major service. I’ve only changed oil, couple sets of tires, the trans fluid and replaced the headlight and marker bulbs a few times . It’s a recall on earlier years but not 2015, again I can’t complain though, I love the car, black/black w leather, nav, moonroof and solar ❤️
    Back to it. I need to change plugs, is it an easy access job? Also noticing people mentioning egr and maf, are they easy access jobs? I’d prefer to replace myself. I have a good set of tools and while it’s been years since I’ve wrenched much, I’m up for it. What else would ppl recommend for the best maint on a g3 with 116k. Also bear in mind that I have a 4x6 utility trailer that I occasionally haul stuff around with, so I am cognizant that it gets a little extra exercise from the occasional pull.
    Kk, thanks in advance for the advise.
  14. Mendel Leisk
    42,296
    For Exhaust Gas Recirculation cleaning see my link (post above yours).
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    SPAM link! it’s listed as “bad flywheel.”
  16. Norryboy1a
    Norryboy1a Junior Member
    Pennsylvania
    I’ve noticed a lot better mileage after changing the engine air intake filter.
    Grit likes this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    which brand?
  18. fuzzy1
    10,690
    Shouldn't a clogged air filter be causing a significant loss of power before it has any noticeable impact on MPG?
  19. Norryboy1a
    Pennsylvania
    no
  20. Norryboy1a
    Pennsylvania
    I think it was a fram
