Service at 5000 miles
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Dec 2, 2012.
  1. Direwulff
    Direwulff Junior Member
    I was told by the dealer they could not turn this off for safety reasons. Reason stated was since car makes no noise in ev mode you could back over someone if you bumped to reverse without noticing... is this not accurate? That beep drives me crazy
  2. Me Here
    Me Here Member
    149
    26
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Toyota covers the first few at any dealer. If you bought an additional prepaid maintenance, then you have to get those done at that dealer.
    Also, there is (generally) no reason to change the oil at the old interval of 5000 miles. The Prius is gentler on the engine than conventional cars because:
    - the "starter motor" is very big and doesn't just kick the engine to get it going...instead it smoothly spins it up, with oil already lubricating everything before gas and a spark is applied
    - the engine is off while driving a lot of the time
    - the engine is off when stopped most of the time while a conventional car idles while getting no miles
    - engine RPM is computer software controlled and not controlled by the whims of a jerky foot
    In addition, you are supposed to be using a synthetic blend of oil that lasts longer.
  4. nudriver
    nudriver Member
    283
    32
    los angeles
    What exactly do they do at the 5,000 mile inspection and how do I know they did it?
  5. Me Here
    Me Here Member
    149
    26
    You should have a booklet in your glovebox. It goes over what should/is checked at each mileage interval.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. nudriver
    nudriver Member
    283
    32
    los angeles
    How do I know they did it? Should I just trust them? At the dealership you can't see them working on your car.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
